sphearical tierod end??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">for the hondas you need to has have a cone shape like this, \ /, as that is how the casting in the knuckle is done.</TD></TR></TABLE>
Not if you drill out the taper.
Or change the taper to the GM size the stock car guys use and run one of these:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley »</TD></TR><TR><TD CLASS="quote">
True.
</TD></TR></TABLE>True.
i have the competition engineering kit. You need to drill the taper out to 1/2" to use the kit.
It replaces the whole tie rod assembly with lightweight aluminum pieces, not just the tie rod ends so it saves some weight which is nice I guess.
edit: i can't find it anywhere on the Jegs website or Competition Engineering's website... Which is funny since I just bought it this summer.... They must have discontinued it really recently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley »</TD></TR><TR><TD CLASS="quote">I've thought about going that route as well, but its a grey area in the HC rules. Not sure its a fight I could win...</TD></TR></TABLE>
I thought about using them too. It's not in the rules????
several HC guys use them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjj »</TD></TR><TR><TD CLASS="quote">
eh i'd through them on, considering suspension bushings are free. I'd make the argument that a ball joint is a suspension bushing.
It is just the drilling of the knuckle that, puts it out of the legal realm for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Jones »</TD></TR><TR><TD CLASS="quote">i have the competition engineering kit. You need to drill the taper out to 1/2" to use the kit.
edit: i can't find it anywhere on the Jegs website or Competition Engineering's website... Which is funny since I just bought it this summer.... They must have discontinued it really recently.</TD></TR></TABLE>
you have this kit?its listed but for mustangs only. did they have a honda kit before?
No. C2418
No. C2418
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Jones »</TD></TR><TR><TD CLASS="quote">i have the competition engineering kit. You need to drill the taper out to 1/2" to use the kit.</TD></TR></TABLE>
Your car wouldn't happen to be an EF, would it? I see the kit is intended for the EG and EK, but I want it for the EF. If your car is EG/EK, could you please take a measurement for me? I'm looking to get the overall length of the inner/outer tie rod assembly; similar to the measurement that Competition Engineering asks you to take during the installation of the kit.
Step 3 from "Disassembly": http://static.summitracing.com...0.pdf
Thanks
Jacques
Thanks
Jacques
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">
Thanks
Jacques</TD></TR></TABLE>
competition engineering tie rod tube = roughly 8.5" long
Thanks
Thanks, but I was after the overall length of the tie rod assembly so I could see if they are long enough or too long for the EF.
</TD></TR></TABLE>Thanks, but I was after the overall length of the tie rod assembly so I could see if they are long enough or too long for the EF.
Thanks, but I was after the overall length of the tie rod assembly so I could see if they are long enough or too long for the EF.</TD></TR></TABLE>
cut and re-thread if its too long.
Too short would be the only issue
From the looks of things, the tubing has a threaded stub welded into either end. This probably wouldn't work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">even easier, cut and re-weld!!!</TD></TR></TABLE>
Either way, I could lengthen (add tubing) or shorten. I was hoping to avoid any fab at all. I'm pressed for time. If I'm going to fab, I'll fab it 100%.
Semi-on-topic question:
Can kits like the CE ones be used to flip the tie rod end to the bottom of the knuckle arm to help fix bump steer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spAdam »</TD></TR><TR><TD CLASS="quote">Semi-on-topic question:
Can kits like the CE ones be used to flip the tie rod end to the bottom of the knuckle arm to help fix bump steer?</TD></TR></TABLE>
absolutely.
absolutely.
