jdm front end question
ok on the stock crx head lights there are 2 bulbs one high and one low and each plug is a different color. i have had my stock head lights out for a little while and i forgot which one is which can anyone help me with that? and for the jdm H4H lights there is only one bulb with three wire coming out the back i know which one the ground is, i just dont know the other 2, which one is high and low beam. i got the front end from passwordjdm.com if that helps. thanks in advance.
you will need a realy on both sides for the lights to function properly the way they work on the sir. when your high beams are on both bulbs light up so when you hook up the single bulbs, both filaments come on when the highs are on. So the bulbs life span is severly shortened. You need to hook up the relay so the high turns the low off when the highs come on.
headlight wiring harness:
pass side:
low beam=red/yellow stripe
high beam=red/blue stripe
ground=black
driver side:
high beam=red/green stripe
ground=black
pass side:
ground=black
driver side:
ground=black
