Axles cable to hydro
front what i have read and have been told if your going to run cable axles on a hydro tranny, for the driver side you will need to use the axle seal from a 90-93 da. you dont have to do anything to the passenger side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaNnYsEvEn »</TD></TR><TR><TD CLASS="quote">front what i have read and have been told if your going to run cable axles on a hydro tranny, for the driver side you will need to use the axle seal from a 90-93 da. you dont have to do anything to the passenger side.</TD></TR></TABLE>
Just wondering.. Is there really proof if it works properly or not?...I'm kinda on a budget..
yes they will, i dont believe that axle seals have anything to do with it becaues they are ordered per the transmission case. just take into consideration your intermediate shaft
from personal experience, I could promise you that the passenger side axle doesn't matter. BUT... If your gonna use 94-00 B-series drivers side, your gonna need the half shaft and the seal for that side of the tranny. If your going to use the 90-93 integra or 88-91 civic crx SiR cable b-series then your going to need the half shaft and tranny seal for that one. I currently run a 94SiR2 B16 in my car with 00 Si tranny and cable axles. I had to use the cable half shaft and the tranny seal from a 90-93 integra cuz the seal from the hydro left a big *** gap and the fluid just poured out everywhere.
Good luck dude! Hope this helps.
sh!ft
Transmission & Drivetrain
Jun 19, 2010 01:12 PM
IntegraG2
Dec 21, 2007 10:51 PM
