TPS positioning
car: 91 crx si
motor: stock jdm b18c siR-g
This is how my TPS sits right now on my intake manifold (stock dual runner):
TPS plug will NOT connect to sensor because heater core inlet is in the way. Even if I remove the fuel line bracket, the top heater core inlet will still be in the way, plus I have to fit a hose there.
Can I just flip the TPS 180 degrees so it's pointing up and not down? The bolts will still line up, and I figure since TPS works off electric current, it just might work but not exactly sure.
YOUR MOM
May 10, 2009 09:10 PM
Ri5e
Mar 27, 2003 06:18 PM
