Need Some Help!!!
Old Jan 18, 2008 | 04:18 PM
jdm_h22's Avatar
Default Need Some Help!!!
Alright, so my brother put a new motor in his eg and it won't start. Here's the neety greety...
It's a d16z6 with d16y8 intake manifold, injectors, and distributor. He's getting spark and from what i can see, everything is set up right. Double checked the firing order and it's good aswell. He pulled his fuel rail to check for gas. He says they were wet w/ fuel.
Any suggestions are very much appreciated.
one last thought... are d16y8 injectors peak and hold??? because he's not using a resistor box.....
Old Jan 18, 2008 | 04:21 PM
z6hatchboy's Avatar
Default Re: Need Some Help!!! (jdm_h22)
The d-series are saturated injectors, i think it may be the y8 i/m, do you know the year of the engine it came off of. The later years have these air hole in them above the injectors(peolpe help me on that one, lol). A rule of hand though, is to always check the timing first if you have fuel/spark/air.
Old Jan 18, 2008 | 08:08 PM
jdm_h22's Avatar
Default Re: Need Some Help!!! (z6hatchboy)
Alright so i wired a resistor box into the harness just to find out that d16y8 doesn't need a resistor box.
I cut all 8 wires trying to figure out how to wire the resistor box. I don't know how to put them back now
I cut all 8 of the wires circled. Does it matter how i solder them back??
Old Jan 19, 2008 | 07:30 AM
jdm_h22's Avatar
morning bump.....
Old Jan 19, 2008 | 08:56 AM
jdm_h22's Avatar
bump....
Old Jan 19, 2008 | 08:59 AM
VRD^don's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_h22 &raquo;</TD></TR><TR><TD CLASS="quote">Alright so i wired a resistor box into the harness just to find out that d16y8 doesn't need a resistor box.
I cut all 8 of the wires circled. Does it matter how i solder them back??</TD></TR></TABLE>
nope doesnt matter which wire goes where..just wire it up.
Old Jan 19, 2008 | 03:09 PM
lnyt9's Avatar
i think your better of taking it to and electrician who knows ...if i was you i would just get a whole new wire hardness from the junkyard or wrecking yard ..should not even cost over fifty buck's...it's only wires
Mikes2000civicsi
Oct 6, 2009 07:43 PM
basktb1188
Aug 14, 2009 06:01 AM
civic minime
12
Aug 22, 2006 03:37 PM
srv3fender
16
Apr 28, 2005 10:06 AM
SSBGSR88
14
Apr 2, 2004 09:57 AM
