B18 head on B16?
I have a B16 longblock that runs perfect with low miles and I also have a B18C1 head with multi angle-valve job and porting. Would you guys reccomend putting the B18 head on my B16 block? or should I look for some other block? Would it be benificial to put it on the b16 block, or would it do more harm than good?
Thanks a lot!
Thanks a lot!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G’Funk »</TD></TR><TR><TD CLASS="quote">I have a B16 longblock that runs perfect with low miles and I also have a B18C1 head with multi angle-valve job and porting. Would you guys reccomend putting the B18 head on my B16 block? or should I look for some other block? Would it be benificial to put it on the b16 block, or would it do more harm than good?
Thanks a lot!</TD></TR></TABLE>
i put a cleaned up gsr head on a gen1 b16 stock bottom end with a smashed header and it made 157 on whitfields dyno a few years ago. its just a high compression b16. if you have em sitting there i say why not.
RomesEM1
Dec 2, 2009 09:14 AM
