Honda S2000 Honda S2000
Smaller tire rubbing more??
Old Jan 18, 2008 | 11:28 AM
al4t1gbundy's Avatar
Default Smaller tire rubbing more??
Hey guys,
I had some 255/35 yoko ES100 tires before they were flattened by a metal bar on the road so I recently picked up some 245/35 yoko avs sport.
The weird thing was with the 255/35 I rubbed only sometimes on a full gas of tank and dips at high speed. I thought with the 245/35 this would be taken care of .. .but its actually maybe rubbing slightly more?
Could this be due to the design of the actual tires?
Old Jan 18, 2008 | 11:39 AM
papa5murf's Avatar
Default Re: Smaller tire rubbing more?? (A08_MThrizzle)
Design of the tire could be one issue, the other could be a waked out alignment.
Old Jan 18, 2008 | 01:12 PM
I dont think alignment could be it because i took one off to put the other one on right away.
Old Jan 18, 2008 | 01:24 PM
B18C GSR CIVIC's Avatar
Simple, you went with a differnt tire company and the contact patch is greater with this tire even though its rated less and this is causing your rub issues,
sucks
just give your rears a slight flare and you should be set.
SiiiAlbert
Oct 25, 2013 03:02 PM
SI_you_later
Honda Civic (2006 - 2015)
14
Aug 23, 2007 06:28 AM
poison
Oct 1, 2006 12:18 AM
.RJ
81
May 7, 2004 11:35 PM
SOHCMAN
Jan 15, 2004 08:11 AM
