Intake and exhaust manifold for d16w7
Hi every one,
it my first thread so please dont kill me
So the thing is that i want to upgrade intake manifold to individual throttle bodies, but did not found any of this done to my engine, which is Europien '03 1,6l VTEC 110bhp d16w7. so i was wondering if manifold would or even could fit from d17 engines, or from previously in 97-00 biuld civics vith d16 engines? The thin is the mounts and intake holes positions and dimensions. So if any one know/tried to fit intakes form other engines, please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nahonda04 »</TD></TR><TR><TD CLASS="quote">wrong forum, what year is your car?</TD></TR></TABLE>
Actually, it is the right forum, seeing as his car is more like an EP3.
http://www.carpages.co.uk/hond...2.asp
but its not an chassis issue, its all about engine...
and its sedan
http://www.cardomain.com/ride/2650438
Modified by kABLiuks at 6:06 AM 1/18/2008
and its sedan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kABLiuks »</TD></TR><TR><TD CLASS="quote">but its not an chassis issue, its all about engine...
and its sedan
Modified by kABLiuks at 6:06 AM 1/18/2008</TD></TR></TABLE>
The pictures help a lot. The engine resembles the D17 rather well. You should be able to use a previous-gen D16 manifold on it, by modifying the bolt up holes a little bit.
and its sedan
thanks, I found recenty some DIY about fitting previous d16 manifold, i think i just should take mine off and check bolts so that i would be able to compare with others
