F23 / F22 / K20 ... EK
Old Jan 17, 2008 | 07:13 PM
hondamark35's Avatar
Default F23 / F22 / K20 ... EK
honestly, when i started out i wasn't even going to put an intake on it...
ok, so i've been reading that i can put k20 pistons in the f23 block i have: great! to make things harder on myself i won't be using the f23 head. instead i'll put an f22 head in it's place.
what i'm getting at is dome-valve clearance. i don't want too much comp. and i don't want bent valves. i'd like to know about these pistons if anyone has anything to say about them. i think this could make for a pretty slick motor if it all fits.
Old Jan 17, 2008 | 07:28 PM
daveedd357's Avatar
Default Re: F23 / F22 / K20 ... EK (hondamark35)
it will work https://honda-tech.com/zerothread?id=1691654 from my motor in 2006
Old Jan 18, 2008 | 12:49 PM
Default Re: F23 / F22 / K20 ... EK (daveedd357)
so you used the RSX pistons on the f23 rods with an f22 head...
ever get a rough figure for your comp. ratio?
Old Jan 19, 2008 | 09:31 AM
soloturbo's Avatar
would an h22 head werk on the f22 block with those (k20) pistons???
Old Jan 19, 2008 | 10:45 AM
thehatchninja's Avatar
Default Re: F23 / F22 / K20 ... EK (soloturbo)
yes it has been done several times. F22A head is better tho.
Old Jan 20, 2008 | 03:03 PM
Default Re: F23 / F22 / K20 ... EK (thehatchninja)
what is it the chamber or the ports or the price.... why is it better?
Old Jan 20, 2008 | 03:18 PM
bisi claims that it's better for some reason, maybe port geometry. There's some people you just listen to. IMO if bisi says it's better, it's better.
Old Jan 21, 2008 | 03:37 AM
soloturbo's Avatar
if it has been done can anyone give info on power or times???
EDIT>>>>saw the dyno chart above....but any other dynos from any1 else
Old Jan 21, 2008 | 11:25 AM
that's the only one I've seen a dyno for, and I've looked around a quite a bit.
Old Jan 21, 2008 | 11:51 AM
soloturbo's Avatar
hondamark35
^^^^^^^^^did you only put in the pistons.....nothing else done to the block or head????
Old Jan 21, 2008 | 12:55 PM
so far this is only a plan. i don't have the pistons or the head yet. i do plan on doing a detailed write up when i start making progress, so keep an eye out for it
Old Jan 22, 2008 | 08:46 AM
soloturbo's Avatar
yea cuzz its a veryy good idea...its worth a try on my side...
1cln_eg9
Jan 2, 2020 10:56 AM
95accord3267
Aug 22, 2014 01:10 PM
jdm.fanatic
Apr 22, 2010 04:28 PM
carlosp38
Mar 15, 2010 03:10 PM
tomlinson619
Apr 15, 2006 03:26 AM
