DA knuckles and stock sohc axles ???
Old Jan 17, 2008 | 06:58 PM
JUN.'s Avatar
Default DA knuckles and stock sohc axles ???
Hi, I know that you can use stock SI or DX knuckles with B series axles by removing a spacer, but can I use some DA knuckle's with stock DX axles ??????
I am not ready to swap the engine yet, But I need new calipers, discs and wheel bearings and I might just buy some DA knuckles for $40 on a junkyard locally.
I will be also changing the Master cylinder to the DA (non abs) and also using a DA's rear disk conversion.
Old Jan 18, 2008 | 03:16 PM
JUN.'s Avatar
Default Re: DA knuckles and stock sohc axles ??? (JUN.)
help
Old Jan 18, 2008 | 03:48 PM
CRX Toad's Avatar
DX axles are the same as Si axles. You will have no problems with DA knuckles.
Make sure you check out the FAQ too.
BIGef
Feb 18, 2012 03:48 AM
soodominican
11
Jan 26, 2010 09:00 AM
92civicfreak
Mar 6, 2007 03:37 PM
Stoich
Sep 28, 2005 02:49 PM
vegaskurt
Jan 20, 2005 08:13 AM
