Suspension & Brakes Theory, alignment, spring rates....
Need Koni shock parts, best way to get them?
Old Jan 17, 2008 | 05:03 PM
nater_1's Avatar
Default Need Koni shock parts, best way to get them?
I need the 12mm ID rear shock sleeve that goes into the rubber top hat and spaces the washers. I bought some shocks used, and am missing the rear sleeves. The stock sleeves are about 2mm too small, and I cant drill them out enough. I also need some ***** so I can more easily adjust them. Does anyone know a source for these parts?
*edit* for anyone needing the topmount hardware, you can purchase it off the koni-na.com website... It is odd since that is the only hardware you can purchase, i guess hondas are diffrent.
Modified by nater_1 at 5:42 AM 1/18/2008
Old Jan 18, 2008 | 06:22 AM
CRX Lee's Avatar
Default Re: Need Koni shock parts, best way to get them? (nater_1)
http://www.koni-na.com/apparel...ory=P
Honda hardware is the third one down. It is the only hardware kit that we stock and sell in volume becasue so many Honda people either lose their hardware or buy the shocks used and don't get the right hardware with themm Happens all the time.
Old Jan 18, 2008 | 07:03 AM
nater_1's Avatar
Thank you crx lee... I have some 13mm sleeves on there now I got from truechoice here in columbus until the 12mm ones get here... I had to get my car back on the road, but should be switching them out asap...
tom_l
Suspension & Brakes
Aug 1, 2007 07:33 PM
MattP
Oct 20, 2005 05:25 PM
SoOHiGH
Suspension & Brakes
May 10, 2005 08:48 PM
1999gs-r
Mar 14, 2005 08:33 PM
Excelesor
Jan 3, 2002 05:35 AM
