215/50/15's on stock rims?
Old Jul 1, 2002 | 06:58 AM
Anyotherone's Avatar
Default 215/50/15's on stock rims?
I want to run Dunlop SP sport 5000 215/50/15's on '95 stock GSR rims. Anyone else heard of this or done this? Would it rub with a 1.5" drop?
I did a search, and the only thread I found was in the Type-R forum.
Thanks ahead of time.
Old Jul 1, 2002 | 09:07 AM
Y2K Si FBP's Avatar
Default Re: 215/50/15's on stock rims? (Anyotherone)
it will rub when turning the wheel all the way or over slight bumps...plus stock rims are 6 inches wide..it 215 will fit..but it's too wide...205-50-15 is much better
Old Jul 1, 2002 | 09:15 AM
tonydatyga's Avatar
215 is pushing it. Other than the cosmetic effect(wheel sunken into a tire), in general only a 10mm over width is recommended. Ie: 205 on a 195 factory equipped piece.
Old Jul 1, 2002 | 10:11 AM
Vazquez911's Avatar
Default Re: 215/50/15's on stock rims? (tonydatyga)
Forget about it...
Under a hard turn full lock, my 205 Ecsta 712s rub. AutoX proven... don't try it on the street.
Old Jul 1, 2002 | 11:13 AM
JCushing's Avatar
Default Re: 215/50/15's on stock rims? (Vazquez911)
heres the question though.... what is your wheel gap height (didstance from wheel to wheel well). what is your suspension setup (how stiff)?
Old Jul 1, 2002 | 11:56 AM
Default Re: 215/50/15's on stock rims? (JCushing)
Right now it's just stock, I'm planning on going with Koni Yellows and Eibach Sportlines.
Thanks for the input everyone!
Old Jul 1, 2002 | 12:18 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Forget about it...
that's interesting, going by that one comparison awhile back of contact patch width on the 712's vs. Azenis, my tires' contact patch is wider than the 712's... my tires don't rub at all anywhere, ever.
Old Jul 1, 2002 | 12:33 PM
junglistgsr's Avatar
Forget about it...
my 205/50/15 azenis are about 217mm wide....way more than my old 205/50/15 Avs intermediates and with both tires i never rub unless im at full complete lock during a hard hard u-turn...and thats only happened once and my car is lowered about 2". I dont know why your tires rub.
orangefit
Honda Fit
Nov 4, 2011 01:54 PM
street_devils
Aug 13, 2008 11:31 AM
Integra21
Nov 10, 2002 12:04 AM
BoroDB8
Jun 7, 2002 04:32 PM
typer77
Feb 16, 2002 09:07 AM
