Signal light problem!
Old Jan 17, 2008 | 11:51 AM
rayccfhk's Avatar
Default Signal light problem!
I have a 97 civic ex and the signal light is going wrong.
when i turn the light on to as panel light is on but headlight is not on, the right signal light is also on (but it shouldn't be!) but not blinking!
when i put on right turning signal, the tail light and brake light blink too!
the left turning signal is normal.
I checked every fuse, and they are all OK!
Can anybody help me...
Old Jan 17, 2008 | 12:30 PM
almostjdmeg's Avatar
Default Re: Signal light problem! (rayccfhk)
I had the same problem in my 95 civic. The thing was i had the wrong bulbs in the turn signals. Just go to your local parts shop and tell them that you need bulbs and tell them what your car is. This should fix it.
Old Jan 17, 2008 | 12:33 PM
rayccfhk's Avatar
Default Re: Signal light problem! (almostjdmeg)
but i didn't touch the bulbs at all?!
why would i have the wrong bulbs then?!
if i need to change the bulbs, which bulb should i change since both front right and rear right signal lights are on
Old Jan 17, 2008 | 01:28 PM
B16B_coupe's Avatar
HRD PKR
I cant understand a damn word you just typed up there, maybe re type that so someone can help.
98dxkoupe
Lighting
15
Oct 12, 2015 05:33 AM
Sparkomatic
Honda CR-V & Element
Nov 16, 2013 01:03 PM
Jimmy92Accord
Jul 23, 2008 09:51 PM
Metal Typhoon
Oct 17, 2006 05:14 PM
niteboyzzz
Oct 4, 2002 11:24 PM
