Not going into first gear smooth enough??
Old Jan 17, 2008 | 10:01 AM
MilanoRedEk99's Avatar
Default Not going into first gear smooth enough??
Like the title says in the morning or whey the car sits for at least 3-4 hrs I start it and let it warm up for at least a min or 2 before I take off, but is really a pain in the neck to put in first gear it takes some time, gotta play with it a little bit first then it will go in. What could be causing this is my clutch going or is it the tranny? I own a 99 civic EX with 145K, thanks in advance.
Old Jan 17, 2008 | 10:07 AM
3lo's Avatar
3lo
when was the last time you changed transmission fluid ?
Old Jan 17, 2008 | 10:20 AM
Default Re: (3lo)
I haven"t done that yet, bought this car about 2 months ago, that's something you recommend I shoud do asap?
Old Jan 17, 2008 | 10:42 AM
Historyg's Avatar
you dam right asap, if you change the fluid you might see a big difference especially if you use mtf because it will perform better in cold weather instead of 10w-40, but people have a difference opinion on that,
Old Jan 17, 2008 | 11:48 AM
3lo's Avatar
3lo
yes change it asap, i doubt that it was changed before, cause the mileage is not that big.
just dont be cheap and dont try to cut corners, use only honda mtf or gm synchromesh friction modified fluid.
Old Jan 17, 2008 | 12:36 PM
fatboy1185's Avatar
Big Cat
Default Re: (3lo)
just pull the shifter down towards second gear, not enough to put it in second, but just a little, then push it straight up into first, should go smooth
_decker
Oct 9, 2017 06:42 PM
sixyearhome
May 6, 2013 06:47 PM
Ilovemydc5integra
Mar 10, 2008 07:06 PM
DMF
Jun 23, 2003 11:15 AM
geminis2k
Feb 23, 2003 12:53 PM
