oil coming out of VTEC solenoid.. i never seen this happen to me b4.
Old Jan 17, 2008 | 08:52 AM
krazy one's Avatar
Default oil coming out of VTEC solenoid.. i never seen this happen to me b4.
its not a lot of oil, but enough that i had to whipe off. started the motor and i watched a lil more come out, whiped it again and drove it around for a lil bit. check it later and i didnt see anything. but i want to prevent this from happening again. so i tried tighten the bolts (i didnt wanna over tighten it), the bolts were fine, is this a sign that i need a new solenoid gasket? wat are some reasons why oil comes out of there?
Old Jan 17, 2008 | 09:06 AM
SuzukaBlueAP2's Avatar
Default Re: oil coming out of VTEC solenoid.. i never seen this happen to me b4. (krazy one)
There should be a gasket there; or is the the screen I am thinking off?
Either way, it's worth a look to see if there is a gasket there. And if there is, replace it.
What engine is this one anyways?
Old Jan 17, 2008 | 10:37 AM
krazy one's Avatar
Default Re: oil coming out of VTEC solenoid.. i never seen this happen to me b4. (SuzukaBlueAP2)
the motor is a 1995 OBD1 B18C1 GSR. this is my 2nd motor i owned (previously owned a B16A1) and i never seen this happen before (so i guess it really shocked me). but then again when i bought this motor, it had more miles on it than my B16A1. so i assume the gasket/screen wears over time? how often should i replace the gasket/screen? TIA
Old Jan 17, 2008 | 01:26 PM
M_87's Avatar
change the gasket *thumbs up*
Old Jan 17, 2008 | 01:40 PM
krazy one's Avatar
its coming out of the top gasket, but im goin to replace both gaskets to be safe. i hope a new gasket fixes it! should i use a liquid gasket (i.e. a silicone) along when i seal the solenoid?
supertace91
Oct 26, 2013 12:56 AM
EKIM NART
Nov 19, 2007 08:43 AM
xgenn786
Oct 27, 2005 04:41 AM
trooper0641
Sep 9, 2004 04:57 PM
brexracer
Mar 27, 2002 04:40 PM
