91 DA suspension.
Okay so I'm starting on my suspension while I wait for my block and some other stuff I ordered to come in. Just wanted some help since this is my 1st build. I'm building a street car to take to the tracks once in a while... I'm going with the tein super street with adjustable damper coil overs. However I would like some recommendation as far as sway bars, traction bars,control arms, tie rods, camber kits, and anything else ya think I should look into that would give great outcome...thanks in advanced to everyone who helps me out. Let me know where to get dem also.
Modified by JDM809 at 10:32 AM 1/17/2008
Modified by JDM809 at 10:59 AM 1/17/2008
The best bar for you car that will make the biggest difference is the suspension techniques rear sway bar. Its 19mm and its a straight bolt-on for the DA. Good luck.
For rear lower control arms - megan, k-sport, omni, skunk2, or be a baller and get function 7's
camber kits- ingalls makes great kits for the DA a bit pricey tho...on my DA i run this ebay kit in the rear made by revo(i think) which is working great so far. as for the front i got the ingalls kit.
since you seem to be doing a suspension overhaul i would suggest getting new bushings. Rear trailing arm bushings make a huge difference too even tho they are kinda a pain in the ***.
Yea thats pretty much what im doing im pretty much building up my DA from the ground up...It's my 1st car and I love DA's so when the summer come ima retire it for a while so i can dedicate alot of time to the build...ima probably be riding around in a eg ferio or bubble for the summer.
