How to adjust tension on alterntor belt
Old Jan 17, 2008 | 06:38 AM
s_vares's Avatar
Default How to adjust tension on alterntor belt
Just a quick question. 97-01
Do you loosen the 10mm adjusting bolt to losten belt.
ive turned it a bit both ways both feel like its going to break. just wanna check.
thanks
steve
Old Jan 17, 2008 | 08:25 AM
vlang29's Avatar
Default Re: How to adjust tension on alterntor belt (s_vares)
you need to loosen mounting bolts before adjusting the adjuster bolt
Old Jan 17, 2008 | 08:40 AM
s_vares's Avatar
which way to turn adjusting bolt. loosen to loosen??
Old Jan 17, 2008 | 08:51 AM
Infinity_Racer's Avatar
Default Re: (s_vares)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s_vares &raquo;</TD></TR><TR><TD CLASS="quote">which way to turn adjusting bolt. loosen to loosen??</TD></TR></TABLE>
yes. make sure you push the alternator down though after you loosen the bolt...
Old Jan 19, 2008 | 03:31 AM
mattsnooz's Avatar
Default Re: (Infinity_Racer)
Yes <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infinity_Racer &raquo;</TD></TR><TR><TD CLASS="quote">
yes. make sure you push the alternator down though after you loosen the bolt...</TD></TR></TABLE> x 2
Its usually corrodid between the "arm's" of the alternator bracket and the mount on your motor. So if you loosen screw but don't push down it didn't really go anywhere.
Old Jan 19, 2008 | 07:46 AM
vinuneuro's Avatar
You need to first loosen the locknut under alternator, then loosen/adjust the with the 10mm bolt in front.
dviladvct1
Nov 20, 2012 10:31 PM
otsegolectric
Mar 21, 2008 04:29 PM
lude1888
Jun 6, 2007 09:26 PM
FBPPrelude
May 22, 2007 12:31 PM
djnikko
Oct 23, 2004 12:28 PM
