How to install: Takata Harness
Old Jan 17, 2008 | 05:32 AM
JDM 101's Avatar
Default How to install: Takata Harness
hello guys. i have a problem on how to install a Takata harness on my EK. which of these bolts should i replace with the eyebolt?
can somebody post some pix on how it was install on this side of the seat.
thanks in advance.
Old Jan 17, 2008 | 05:51 AM
JShull's Avatar
I'm gonna go out on a limb and say the yellow one. It should take the place of the stock lap belt correct?
Old Jan 2, 2013 | 04:51 AM
jestin91's Avatar
Default Re: How to install: Takata Harness
Bump on old there'd need help installing bar
Old Jan 2, 2013 | 06:06 AM
grumblemarc's Avatar
The Grumpiest
For a second I thought Google was beoken.
https://www.google.com/webhp?sourcei...w=1401&bih=886
https://www.google.com/webhp?sourcei...6&pf=p&pdl=300
Old Jan 2, 2013 | 07:42 AM
dirty19's Avatar
Ridin Dirty in Cali
No harness bars.
Those things will not protect you during an impact.
It will bend and you will either come out of the harness or you will faceplant into the steering wheel or windshield.
Just for grins go wrap one strap to it and pull firmly.
There will be a amount to give to it.. now imagine you hitting something, the force will be many many many times more greater.
If you want or must have a harnesses use a roll bar that is bolted to the car itself.
I also dont condone those in a street car either,but if you take that route pad everything any part of your body might hit, why? Seatbelts and harnesses stretch on impact something can and most likely will hit something else in your car.
Your stock seatbelts will be much more safer than those green gobblin ones you want in the car.
Old Jan 3, 2013 | 10:50 AM
H22swag's Avatar
i got a harness bar it doesn't allow people into the back seats but it looks better and is safer
Old Jan 3, 2013 | 10:52 AM
The Grumpiest
Actually, it is not and I have a custom made one stronger than any OTS bars.
Old Jan 3, 2013 | 11:10 AM
Libertariat's Avatar
Ek Forever y0!
Originally Posted by dirty19
No harness bars.
Roll cages should really be welded to the car to optimize safety with using a harness.
OP: Do you have a roll cage at all? You do realize that in the event you flip your car that your harness is more likely to kill you if you don't have a roll cage and a helmet on.
importuner_sc
Apr 28, 2008 11:31 AM
Mag00n
10
Aug 4, 2006 10:12 AM
teggytegteg
May 13, 2004 02:27 AM
Yellow-R-689
Mar 13, 2003 04:49 PM
