Suspension & Brakes Theory, alignment, spring rates....
da rear lower arm in a 88hb std
Old Jan 16, 2008 | 09:25 PM
88hbz6's Avatar
Default da rear lower arm in a 88hb std
My stock rear lower arm is bent on my 88hb std model , so i need to put in a another one. I have 90 da lower arms. I took look but it looks like i might need to put the da damper to make it fit. Will it bolt right up or will it mess up my alignment?
Old Jan 17, 2008 | 03:22 PM
BlueIntegraBoy's Avatar
Default Re: da rear lower arm in a 88hb std (88hbz6)
It should fit.
Old Jan 17, 2008 | 03:39 PM
Tyson's Avatar
it'll "fit", but it wont be the right control arm to use. and yes, since you have 88 control arms, you need a different shock for it to fit. so you wont be able to use the shocks you have on there now.
DA control arms are the odd ones. theyre a tad longer, so they will mess up the alignment, and they put the shock in the wrong place.
you COULD use EG/DC control arms, the geometry is the same. but again, youll still need different shocks.
Dohc eg coupe
Dec 17, 2012 06:20 PM
ELISR20DET
Sep 23, 2008 03:07 PM
91redteg
Mar 16, 2008 09:36 PM
Slvr_CRX
Apr 24, 2004 04:22 PM
NCchris
Jul 25, 2003 05:04 PM
