b18c1 built, but i want more power what did you recomend
block:
polish and balance crank
eagle H-bem rods
srp pistons .20 over cp no sure about 10:1 or 11:1
head:
p72 p&p three angle valve job
crower springs and retainers
ctr cams
tranny is a stock gsr.
ecu:
apexi power FC
my plans for it are the following:
I want to make more power i allready decided to upgrade my cams, pistons, put a lighter flywheel on it and ITB,s
what did you think are the best cams and piston for this kind of setup?
ps:I want to keep it n/a
eagle H-bem rods
head:
ctr cams
ecu:
apexi power FC
i say boost but liek u said u wanan stay n/a
toda make a good header and u could invest in come after market cams.. that would be a nice bump u could sleeve the block 2 a 2liter that will give u liek 10-15 hp just buy going 84mm. but thats pricy and reqiers new pistons but if u do that u can bump up ur compression
what you need to do is invest in a custom header and some aftermarket cams
Also if you want to make your times drop alot get a final drive ratio as well! It will shed some serious time but will cost you in your top speed.
I been looking around and i found the folowing parts:
set of arias pistons 85mm bore 13:1 cp, and howards aluminuim racing rods for a 93mm crank. I considering buying them but i want to ask you'll about it first.
Also a friend of mine is selling me a ctr tranny.
and last do you think i should get rid of the apexi power command unit and go with something else.
if the power fc is working fine i see no reason to replace it.
also, you do realize what you'll have to do in order to run those pistons and rods dont you?
bracket 4 life
Apr 17, 2005 09:51 PM
adro2333
22
Jun 18, 2004 10:38 AM
J2turbo21
Mar 10, 2003 12:01 AM
