Determine gear ratios
Old Jan 16, 2008 | 06:05 PM
DrSeuss's Avatar
Default Determine gear ratios
Is there anyway to determine my final drive and gear ratios when the tranny is mounted? Should I put the car on jackstands and turn the crank pulley with the car in 4th gear?
My tranny has a label on it that says S80. But looking at the Fatboy gear calculator, there are 3 S80 tranny configurations. I bought a JDM motor and tranny w/ LSD from HMotors. Does that mean I have the S80 with 4.4 FD and 3.23/1.9/1.36/1.034/0.787 gears?
Old Feb 6, 2008 | 05:02 PM
Bunger's Avatar
Default Re: Determine gear ratios (DrSeuss)
You could do what you are describing to figure out the trans you have, but I think your guess is right, and you probably have the S80 out of the 93-01 JDM SiR.
gilou bilou
Nov 11, 2005 09:05 AM
charjacq
Jul 27, 2004 01:13 PM
jdmhondageek
22
May 3, 2003 07:34 PM
