Another CEl problem but it never comes on
im havin a problem in my 95 del sol si, previous owner blew the z6 that was in it so i swapped the head on to a b7 block that i had. the car will start and run ok with a little surge in the idle, but what concerns me is the CEL NEVER comes on. it doesnt come on with the key on before startup nor when i bridge the connection. the light is good as i swapped it out with the oil pressure light which was known good because it lit up. all my fuses are good and i have checked them at least twice. could i have missed a ground somewhere? the only wiring i have messed with is doors ( removed a lambo door kit that was FUGLY, and wich was wired as a fire hazard) and the engine wiring just plugging and bolting leads on.. is there any in line fuses that might go to the CEL or is my ECU bad.. i have a P06 ecu but i dont think it will work with my setup... any help is greatly appreciated.
oops once i read the post it sounded like i was runnin the p06 but currently in the car is the stock p28... thanks
honda_aus87
Mar 26, 2011 08:01 PM
