Clutch Master Cylinder, are they the same???????????????????
Old Jan 16, 2008 | 02:43 PM
philosofy1's Avatar
Default Clutch Master Cylinder, are they the same???????????????????
well, i realized today that my clutch master cylinder is slowly but surely leaking. so i want to replace it before i decide to drive it and it craps on me. so i know this might sound like a noob question, but is the ITR clutch m/c any different from the rest that honda uses. i know the brake one is different, but wasn't sure if the clutch was.
also, how is the omni one. is it worth it? i know when it first came out there was alot of problems, just wondering if i should stick with oem.
Old Jan 16, 2008 | 02:49 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Clutch Master Cylinder, are they the same??????????????????? (philosofy1)
I would have to say they're the same. It looks to me as if 92-00 Civics and 94-01 Integras use the same MC, regardless of B or D-series. Checking part #s will answer your question for sure.
Old Jan 16, 2008 | 03:00 PM
philosofy1's Avatar
Default Re: Clutch Master Cylinder, are they the same??????????????????? (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">I would have to say they're the same. It looks to me as if 92-00 Civics and 94-01 Integras use the same MC, regardless of B or D-series. Checking part #s will answer your question for sure. </TD></TR></TABLE>
yeah i checked part numbers already, the only thing that is different is the middle 3 numbers, everything else is the same.
how is the omni one? is it worth the $200? just curious, if not i'll stick with oem.
Old Jan 16, 2008 | 03:10 PM
BryanM.'s Avatar
Resident Gearhead
I don't have any experience with Omni MCs. I buy NAPA MC for about $110, haven't had issues with them.
Old Jan 16, 2008 | 03:15 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">I don't have any experience with Omni MCs. I buy NAPA MC for about $110, haven't had issues with them.</TD></TR></TABLE>
$110, wow, i would have thought NAPA to be alittle cheaper. yeah i've also seen Advanced sell theirs for $110 as well. OEM ones are $120, so i think i'm going to go with that. $10 more, and i'll sleep alittle better at night.
Thnaks man!
Old Jan 16, 2008 | 06:41 PM
ca-rs's Avatar
I have a good used one I'll sell for $25 shipped
Old Jan 16, 2008 | 06:42 PM
BlueIntegraBoy's Avatar
All 94-01 Integra and 92-95 Civic are interchangeable. I believe the 96-00 Civic is interchangeable as well.
Old Jan 17, 2008 | 07:18 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: Clutch Master Cylinder, are they the same??????????????????? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">All 94-01 Integra and 92-95 Civic are interchangeable. I believe the 96-00 Civic is interchangeable as well.</TD></TR></TABLE>
Yeah, I thought they all looked the same and pushed the same volume of fluid. I know that the Integra brake MC pushes more than the Civics w/ drums.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
Thnaks man! </TD></TR></TABLE>
REALLY? $120? I think I'll stick to genuine Honda MCs from now on...
Old Jan 17, 2008 | 12:34 PM
Brick Top's Avatar
how is the omni one? is it worth the $200? just curious, if not i'll stick with oem.</TD></TR></TABLE>
the omni will stiffen and shorten the pedal and engagement quite a bit, depending on what pressure plate you have. kinda like upgrading to an itr brake mc over a civic brake mc, the omni is bigger than an oem. if you already have an aftermarket pressure plate, this will make it alot stiffer.
MoogieBoogie
17
Aug 12, 2013 11:53 AM
ZenDynasty
24
Jun 1, 2008 07:56 PM
jdmeg9
Jan 21, 2006 05:56 PM
acuracy r
Jul 13, 2005 06:15 AM
