Engine Damper Kit.... worth it?
if you want a real upgrade add motor mount inserts, or fill with polyurethane. they will do the job much more effectively than those little dampers. this is all my opinion and I've never used one of those dampers but because of the above I never felt I needed to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkimN »</TD></TR><TR><TD CLASS="quote">if you want a real upgrade add motor mount inserts, or fill with polyurethane. they will do the job much more effectively than those little dampers. this is all my opinion and I've never used one of those dampers but because of the above I never felt I needed to</TD></TR></TABLE>
ESP poly mounts FTW! Tested up to 650 whp
B18C
Oct 16, 2001 12:42 PM
