98 F23 Vtec + 94 F22 Vtec = SAME header bolt pattern?
Old Jan 16, 2008 | 12:31 PM
Honda_Fanatic's Avatar
Default 98 F23 Vtec + 94 F22 Vtec = SAME header bolt pattern?
Do they share the same header bolt pattern or no?
Old Jan 16, 2008 | 01:06 PM
BlkChryKord's Avatar
If it says F22B1 on the 94 then yes.
Old Jan 16, 2008 | 02:39 PM
Default Re: (BlkChryKord)
Thanks
Old Jan 20, 2008 | 07:58 AM
jayhonda123's Avatar
no the f22 is a long blok the f23 is a short block
Old Jan 20, 2008 | 11:53 AM
Alpinestar03's Avatar
wtf?^^
jayhonda123..
you dont know wtf your talking about...
Long block= complete motor
Short block= Just the block
And im almost 1000% shure the f22b1, h23 and f23 head ports are identical. The non-vtec ports for cylinder 2 and 3 are siamesed. Opposed to the vtec head which have equal spacing inbetween each port.
Eric
Old Jan 20, 2008 | 11:56 AM
street_accord94's Avatar
Default Re: (Alpinestar03)
h23 has a different port design than f22b1/f23 engines.
and jayhonda123 may want to just log out now. long block/short block is a matter of what components are included with a specific motor, not an entirely different motor style.
Old Jan 20, 2008 | 12:09 PM
my bad, i fugured the f22b1 and teh f22A'S identical. A h23 header/maifold will bolt up to a F22Ax head though. I did a h23 head swap on my cousins boyfriends 97 CL and i used the stock manifold.
Turtle732
Mar 10, 2010 07:23 AM
cjmurillo
Oct 9, 2008 03:00 PM
89preludefl
Feb 6, 2008 10:47 PM
Sam1am26
Oct 19, 2006 10:57 PM
