Honda S2000 Honda S2000
Finally did my first oil change since owning the S
Old Jan 16, 2008 | 12:27 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Finally did my first oil change since owning the S
Just finished doing my first oil change with the S @ 53K miles. I jacked it up correctly with the driver side higher so all if not most of the old oil drained out. Weather in SoCal has been very nice lately so I've been riding top down and the hard top is in storage.
Old oil & filter:
Mobil 1 SuperSyn 10w30
Fram oil filter
New oil & filter:
Castrol Syntec 0w30 GC (Made in Germany)
- very heavy 30 weight oil, superior to its U.S. counterpart
Purolator PureONE filter
Next up at 60K is the differential fluid.
Some pics:
I ♥ Castrol Syntec GC
The difference between the two oil filters:
Will be putting the hard top back on when forecasts call for rainy days.
Old Jan 16, 2008 | 12:47 PM
jdm j's Avatar
Default Re: Finally did my first oil change since owning the S (NightRiderS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRiderS2K &raquo;</TD></TR><TR><TD CLASS="quote">Old oil & filter:
Fram oil filter </TD></TR></TABLE>
IMO, I think Mobil 1 syn is better than the one you purchased, in fact mostly everyone that I know uses it including myself and people on this forum. Also, I think that the Fram filter is better than the one you purchased as well.
Old Jan 16, 2008 | 12:49 PM
ReddotsS2K's Avatar
Default Re: Finally did my first oil change since owning the S (jdm j)
Orange death ftl
Old Jan 16, 2008 | 12:51 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
You are aware that mobil one makes 0w30 and ow40 weights too right?
Old Jan 16, 2008 | 12:55 PM
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm j &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think Mobil 1 syn sucks, in fact mostly everyone that I know of uses it including myself and people on this forum.</TD></TR></TABLE>
Most people on here use it because it's readily available everywhere including the 5 quart jug from WalMart...Most people also use it because that's the only oil they have known that people swear by and because of the fact that Mobil 1 is used by the Honda racing team...
I used to use Mobil 1 SuperSyn when my GSR was N/A and boosted... It used to burn off nearly 1 quart/3000+ miles. Most of the users on the oildrop forums also concur that Mobil1 tends to burn off in Honda engines. Ever since I've switched to Castrol Syntec GC (in my GSR, it burned off less oil and my car seemed to run better over all).
The bottles of Castrol Syntec I have are left overs from when I still have my Integra. From researching on bitog.com, I have concluded that:
Mobil 1 SuperSyn &lt;= Castrol Syntec (U.S.) &lt; Castrol Syntec 0w30 (GC/Made in Germany/European Formula)
Unless you prove me wrong that Mobil1 SuperSyn 0w30/5w30/10w30 trumps Castrol Syntec 0w30 German Made (NOT THE U.S. version!!) will I stop recommending this to people...
BTW...Do some research there
http://www.bobistheoilguy.com/...s.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">Orange death ftl </TD></TR></TABLE>
Seriously...I can't believe the old owner even used that oil filter on there! It's all good though... because he sold his S to me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">You are aware that mobil one makes 0w30 and ow40 weights too right?</TD></TR></TABLE>
I am very aware of that. I just prefer Castrol Syntec over Mobil 1 SuperSyn. The Castrol Syntec 0w30 German Made is actually a very heavy 30 weight oil and is almost a 40 weight oil. It is superior to the Castrol Syntec 0w30 that is manufactured and made in the U.S.
Old Jan 16, 2008 | 01:57 PM
jdm j's Avatar
I'm a have to try out Castrol Syntec then since I plan to go FI soon. Anyhow, I'm down to experiment, so no hostility there....
Old Jan 16, 2008 | 02:02 PM
SilverDc2's Avatar
Default Re: (jdm j)
good stuff.
treat her good.
Old Jan 16, 2008 | 02:17 PM
Firstoost's Avatar
Default Re: (SilverDc2)
I use Eneos 5w40 along with an OEM Honda filter and it works great.
Nice to see another tried and true oil out there. Ever thought about doing a baseline with the regular oil then doing a baseline with the Castrol GC?
Old Jan 16, 2008 | 02:31 PM
Sean Juan's Avatar
Default Re: (Firstoost)
Wait, so why did you tell us you did an oil change? Is there a reason to this thread at all?
Why are you going to run a heavy oil on such a high revving car? There's nothing wrong with burning a little oil as long as it's getting the proper lubrication. Don't hinder your car's performance in the sake of not burning oil.
Old Jan 16, 2008 | 03:20 PM
bigmacnfries's Avatar
Default Re: (Sean Juan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean Juan &raquo;</TD></TR><TR><TD CLASS="quote">Wait, so why did you tell us you did an oil change? Is there a reason to this thread at all?
Why are you going to run a heavy oil on such a high revving car? There's nothing wrong with burning a little oil as long as it's getting the proper lubrication. Don't hinder your car's performance in the sake of not burning oil. </TD></TR></TABLE>
I agree - some modern performance cars are designed to use a bit of oil (Audi RS4 needs oil really often) - heavy oil won't burn off, but can actually hinder performance. Of course i could be talking complete
Old Jan 16, 2008 | 04:05 PM
Firstoost's Avatar
Default Re: (bigmacnfries)
30 is heavy? Why would Honda recommend an incorrect oil?
Old Jan 16, 2008 | 04:07 PM
Honda don't recommend a very heavy weight oil.
Old Jan 16, 2008 | 04:11 PM
M.A.R.C.'s Avatar
I am very aware of that. I just prefer Castrol Syntec over Mobil 1 SuperSyn. The Castrol Syntec 0w30 German Made is actually a very heavy 30 weight oil and is almost a 40 weight oil. It is superior to the Castrol Syntec 0w30 that is manufactured and made in the U.S. </TD></TR></TABLE>
i gotta agree with the mobil 1 oil burning. my turby gsr uses to fkn drink that ****. anything else it was ok
Old Jan 16, 2008 | 04:15 PM
ntensehonda's Avatar
Default Re: Finally did my first oil change since owning the S (M.A.R.C.)
Royal Purple 10W-30 and Honda OEM filter for me.
My gas milage went up 3mpg.
Old Jan 16, 2008 | 06:01 PM
Black S2K's Avatar
I use Mobil 1 SuperSyn 10w-30 with the Mobil 1 filter. I do burn about a 2/3 of a quart every 3k but hey thats what 6 quart boxes are made for 5 in now 6th when needed.
Old Jan 16, 2008 | 06:14 PM
In-N-Out Burger
So much hostility. This thread is also open to the discussion of different usage oils in our cars.
If I have easy access to a dyno, I would gladly do a base map dyno with regular oil vs different synthetic oils.
Royal purple & Amsoil are up there with GC. As for Eneos, the Nippon oil of Japan---Too expensive for me as I don't even do any serious tracking. Just daily driving for now.
0w30 is not heavy at all for the s2000...If anything this oil will improve valve train noise.
jdm j: I too plan to keep using this oil even when I go FI.
Old Jan 16, 2008 | 07:11 PM
f22b-dohc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M.A.R.C. &raquo;</TD></TR><TR><TD CLASS="quote">
i gotta agree with the mobil 1 oil burning. my turby gsr uses to fkn drink that ****. anything else it was ok</TD></TR></TABLE>
+1
my old accord and my friends scooby use to burn (dissipate?)mobil as well....
stopped using it since then....
Old Jan 16, 2008 | 10:44 PM
Dr. EKology's Avatar
Default Re: Finally did my first oil change since owning the S (f22b-dohc)
+2. My B-series used to drink it like cheap mexican beer. I actually blame Mobil1 for speeding up ring damage.
I for one am fine with sacrificing a few hp for the sake of the oil lasting longer. I'm not going to check my oil level weekly which was what it came down to with Mobil1.
Regular Castrol 5w-30 ftw.
Old Jan 16, 2008 | 11:21 PM
s2000 mf's Avatar
Default Re: Finally did my first oil change since owning the S (Dr. EKology)
Just stick with OEM PCX filter it has been discussed many times.
Old Jan 17, 2008 | 04:47 AM
In-N-Out Burger
Default Re: Finally did my first oil change since owning the S (s2000 mf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2000 mf &raquo;</TD></TR><TR><TD CLASS="quote">Just stick with OEM PCX filter it has been discussed many times. </TD></TR></TABLE>
I'm sure the OEM PCX filter is good, but I know for a fact that this is how the rank goes in terms of flow rate:
K&N (too expensive) &gt; Purolator PureOne (I can get for $5) &gt; Honda PCX filter &gt; leading brand A, B, C
Old Jan 17, 2008 | 07:40 AM
B18C GSR CIVIC's Avatar
Mobile 1 has been great to me over the past 10 years and been fine with many 400+ whp cars of mine
and great on the s2
Old Jan 17, 2008 | 08:01 AM
lYellowDragonl's Avatar
royal purple FTW!
Old Jan 17, 2008 | 09:06 AM
JDMAkon's Avatar
Default Re: (lYellowDragonl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lYellowDragonl &raquo;</TD></TR><TR><TD CLASS="quote">royal purple FTW!</TD></TR></TABLE>
Old Jan 17, 2008 | 04:54 PM
In-N-Out Burger
Default Re: (B18C GSR CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C GSR CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">Mobile 1 has been great to me over the past 10 years and been fine with many 400+ whp cars of mine
and great on the s2 </TD></TR></TABLE>
I guess you've never tried Castrol Syntec GC.
It's not readily available as the only place I know that sells it locally is in Lake Forest AutoZone.
Old Jan 17, 2008 | 07:29 PM
omg_miiiike's Avatar
Default Re: (NightRiderS2K)
More pictures of your car ? I'm contemplating doing black wheels as well ..
