P28 or P30 for a b16 sirII swap?
Old Jan 16, 2008 | 12:14 PM
santacruzccs's Avatar
Default P28 or P30 for a b16 sirII swap?
what would be better..pro's and con's?
Old Jan 16, 2008 | 12:16 PM
crazyguy's Avatar
Default Re: P28 or P30 for a b16 sirII swap? (santacruzccs)
i have exact engine as u do and ran a p30 ecu (jdm) that came with the swap but it made my car run like ****. unstable idel, knock sensor came on, traction control came on. so i switched it to a chipped p28 ecu tune by a pro and the car has been running very smotth then. no more check engine light
this guy chips the best ecu ever.
http://www.phearable.net/
Old Jan 16, 2008 | 12:30 PM
rpared01's Avatar
p28 is for the single cam v-tec, while the p30 is for a b16. I would say go with a P30.The P30 is made for the that engine.
Old Jan 16, 2008 | 12:32 PM
crazyguy's Avatar
Default Re: (rpared01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpared01 &raquo;</TD></TR><TR><TD CLASS="quote">p28 is for the single cam v-tec, while the p30 is for a b16. I would say go with a P30.The P30 is made for the that engine.</TD></TR></TABLE>
p28 can be chipped .actually p30 can be too
Old Jan 16, 2008 | 07:41 PM
rpared01's Avatar
true, but if he's going to run the motor stock then he's better off running a stock ecu. Just my $ .02
Old Jan 16, 2008 | 07:46 PM
z6hatchboy's Avatar
Ok, if they're stock ecu's use p30. Like crazy guy said, if they're chipped it doesnt make a diff
Old Jan 16, 2008 | 08:04 PM
ekBlackHatch's Avatar
go with the pr3 or p28 unless you dont care about passing emmissions is this your dd? jdm ecu cant pass with
Old Jan 22, 2008 | 07:52 AM
Default Re: (ekBlackHatch)
pr3 is obd-0
best ECU to use is a chipped p28
won't check for knock sensor. Gas will be off buy maybe 30 miles over the stock p30 ECU.
Old Jan 22, 2008 | 08:15 AM
slacks's Avatar
Default Re: (vega_ROCKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vega_ROCKS &raquo;</TD></TR><TR><TD CLASS="quote">Gas will be off buy maybe 30 miles over the stock p30 ECU.</TD></TR></TABLE>
what do you mean by that?
Old Jan 22, 2008 | 08:40 PM
Default Re: (slacks)
I'll double check with the milage is
i have recorded the Miler per Tank w/ the p30 yet.
I was just guessing on that one
Old Jan 22, 2008 | 08:48 PM
wangkata's Avatar
P28 or P30 either way
Old Jan 22, 2008 | 09:37 PM
LastGenEK's Avatar
Default Re: P28 or P30 for a b16 sirII swap? (wangkata)
Both Very good ecus, p30s are a little harder to come buy in the usa
Old Jan 22, 2008 | 10:25 PM
electron_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vega_ROCKS &raquo;</TD></TR><TR><TD CLASS="quote">pr3 is obd-0
won't check for knock sensor. Gas will be off buy maybe 30 miles over the stock p30 ECU.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vega_ROCKS &raquo;</TD></TR><TR><TD CLASS="quote">I'll double check with the milage is
I was just guessing on that one</TD></TR></TABLE>
are you drunk vega???
EJ SIR
14
Feb 19, 2009 01:55 PM
crazyguy
Jun 6, 2007 01:49 PM
russianswty
Oct 19, 2006 07:36 PM
1truelovedstd
Jul 28, 2005 10:05 AM
B6teen
Apr 25, 2005 01:39 PM
