Prelude won't start
Old Jan 16, 2008 | 07:30 AM
LSBeast's Avatar
Default Prelude won't start
96 S model. Only way I can get it to start is by hitting the bottom of the stearing column.
Battery is good and I hear the fuel running when I starting it up, but it just makes a clicking sound. It does not turn over. Also jumps starting it or cables don't either. Any ideas? I don't think its the relay because it does not turn over and I can hear the fuel pump I think its.
Hope that makes sense!
Old Jan 16, 2008 | 07:39 AM
Hawkze_2.3's Avatar
Default Re: Prelude won't start (LSBeast)
Sounds like it could be your ignition switch. Those seem to start going out around this time...
It's a $40 part from Honda and it's pretty easy to change.
http://www.hondaautomotivepart...WITCH
Old Jan 16, 2008 | 11:42 AM
LSBeast's Avatar
Default Re: Prelude won't start (Hawkze_2.3)
I took it to the shop........$231.00 it was the starter. They had me test it when I first got there. While I turn the key the tapped the starter and the car started like nothing.
Now the battery is drained some how.....and they said I should pick one up at Autozone asap.....I have had this car for 3 years now, and theres no telling when it was last changed out. Thanks for the advise though. The ignition switch may be next on the list.
Old Jan 19, 2008 | 07:41 AM
shanehate's Avatar
231.00?! I got one at a junkyard for 30 dollars
chris riz
Sep 19, 2011 04:51 PM
jdmunlimited1
Apr 3, 2010 05:47 PM
br3ak3r84
Sep 30, 2006 11:23 AM
EvilKokonut
May 30, 2005 08:54 PM
UNDER PRESSURE
Jun 21, 2004 08:47 AM
