Clutch Doesnt fully disengage?what to do?
Old Jan 16, 2008 | 07:11 AM
eg1107's Avatar
Default Clutch Doesnt fully disengage?what to do?
i have a 93 eg coupe with a b16a swap, and my clutch isnt disengaging completely. Even in neutral the car moves when i let off of the clutch. what do i do?its a stock clutch. thanks
Old Jan 17, 2008 | 08:27 PM
ludenoob99's Avatar
Default Re: Clutch Doesnt fully disengage?what to do? (eg1107)
i'm guessing the car is also hard to shift too if the clutch wont dissenguage properly. first see if you can puch the clutch fork back manualy to ge the clutch to dissenguage, if you can then there is a probem wih your clutch cable/pedal adjustment. if you cant then there is in internal problem.
Old Jan 17, 2008 | 08:32 PM
bpkmrtoes's Avatar
Default Re: Clutch Doesnt fully disengage?what to do? (ludenoob99)
did you just swap it in or was it fine before?
Old Jan 17, 2008 | 09:14 PM
speedooo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg1107 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 eg coupe with a b16a swap, and my clutch isnt disengaging completely. Even in neutral the car moves when i let off of the clutch. what do i do?its a stock clutch. thanks</TD></TR></TABLE>
a. you're rolling, it's this thing called gravity
b. you dont know what you're talking about
c. you added it for dramatic effect
d. your transmission is messed up really bad
Old Jan 28, 2008 | 05:48 AM
eg1107's Avatar
Default Re: Clutch Doesnt fully disengage?what to do? (bpkmrtoes)
naw it been like tht since i did the swap.
Old Jan 28, 2008 | 06:01 AM
Swerv's Avatar
Geez, people are so nice these days... Anyway is it a hydraulic clutch or cable? Wouldn't you have had to swap to hydraulic for your engine swap? Try bleeding the clutch and refilling it with fresh DOT 3 fluid would be my best suggestion. Gotta start somewhere.
meece0927
Jul 2, 2013 08:15 AM
Haarstad
Jun 24, 2012 09:50 PM
I_dont_want_a_user_name
Jan 13, 2007 06:15 AM
.water
Oct 16, 2004 05:24 PM
rody084
Mar 23, 2004 06:00 AM
