Stainless steel welding
Old Jan 16, 2008 | 04:00 AM
TurboEK9Coupe's Avatar
Default Stainless steel welding
I was welding some 3/16" stainless steel and the weld was turning black on me. I cleaned the welded area and it looks like it was contaminated. I was welding the end of two pieces together and I'm thinking that I needed to back flow Argon gas on the inside of the box. Any input would be great.
Old Jan 16, 2008 | 05:08 PM
ismkv8s's Avatar
Default Re: Stainless steel welding (TurboEK9Coupe)
you can just use solar type b flux its for use with stainless. Also are you moving to slow with to much heat? That how one of the guys welds are at work almost black and I showed him turn down the heat a bit and move a little faster. Itmigght work for you.
b16bri
Welding / Fabrication
Oct 11, 2011 04:28 PM
andyvaj
Sep 2, 2007 05:55 PM
SilverWarrior
Jun 4, 2007 10:01 AM
TurboEM1
Mar 11, 2006 08:46 PM
Pikachu
Nov 1, 2005 08:12 PM
