Need Help, gota h22 in my ek hatch and......
Need Help, In search of a short shifter but dont kno where to start.
the reason is, i have a h22 in my ek hatch and i dont know what to search?
do i search for a prelude short shifter or a civic short shifter?
i was told i mite be needing an adapter of some sort?
I did not do the swap myself so i dont kno what shift linkage they used.
let me kno if you can HELP, and yes i tried searchin but i got nothing.
another question
i found a skunk 2 short shifter for cheap and it came off a da and the guy said it would fit 92-00 civics.
will this shifter be able to work with my ek hatch witha h22?
Modified by whiteef-8 at 6:47 PM 1/23/2008
another question
ummmmm DC sucks nuts. its more like day and day only you ruin your syncros over time with a DC. You need the 4bidden motorsports short shifter for the 4th gen prelude. It is the only short shifter that has been proven to work with a prelude. In your case you will treat this as if the civic is a prelude lol. its $110 i believe but well worth your money. Like the post above, its like day and night.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude »</TD></TR><TR><TD CLASS="quote">ummmmm DC sucks nuts. its more like day and day only you ruin your syncros over time with a DC. You need the 4bidden motorsports short shifter for the 4th gen prelude. It is the only short shifter that has been proven to work with a prelude. In your case you will treat this as if the civic is a prelude lol. its $110 i believe but well worth your money. Like the post above, its like day and night. </TD></TR></TABLE>
lol dumbest post ive ever read. a short shifter doesnt expletive with your synchros...shifting to quickly and beating the **** out of your car screws your synchros.
@ the op: an h22 uses cable linkage from a prelude so you need a prelude shifter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo »</TD></TR><TR><TD CLASS="quote">
@ the op: an h22 uses cable linkage from a prelude so you need a prelude shifter.</TD></TR></TABLE>
dumbest post ever. Because it uses shift linkage the short shifters have a tendacy to loosen and in turn cause your shifts to become incomplete and grind, and in the end expletive your tranny. There are quiet a few stories about the DC adapters expletiveing up trannys.
i gota a question
Modified by whiteef-8 at 7:42 PM 1/23/2008
im pretty sure it should fit...but how did figuring out your shifter come to getting a new one...try and see if you can find a shift bowl online...thats what i had in my integra with the h22...i had a custom shift bowl to keep things in place...it might be different but iono...G/L
Ok let me make this clear NO it will not work. Notice how I put No in bold twice. For a prelude regardless of what car its in you need a prelude short shifter unless you are running the h2b kit. DC short shifter adapter is ok but its just an adapter and tends to flex. I would go with the forbiden or one like it.
blackedoutcivic
Feb 28, 2003 01:45 PM
