problems with eg guage cluster!!! HELP!!!
Ok so I was driving the other day and all of a sudden my gauges stopped working. I have a dx hatch with the cluster with the tachometer installed. My speedo, tach, temp and gas guages dont work. Also my engine lights (CEL, oil, seatbelt, trunk, etc) dont work now either. I also have no turn signals, BUT my hazards still work. I still have lights and highbeams and brakes. Also the high beam indicater light still lights up, while no other light indicaters work....
Oh ya, also its a obd-II b18b1 swap, I am using a jumper harness and running the obd-II ECU.
I am going nuts over this trying to figure out whats wrong. I swapped it back to the original cluster to test it and same thing, so I know its not the cluster itself. Im hoping its a fuse or something somewhere, but I have NO IDEA which fuse it would be because theres nothing specific to the guages that I know of. I have no idea what its tied up to or what it could be related to. Could someone please point me in the right direction? Thanks
so basically your entire cluster doesn't work? as in headlights work but cluster doesn't light up? if so then i had this happen to me a super long time ago.. it was infact a fuse in the dash and it wasn't labeled.. this was a super super long time ago so i'm not sure which fuse exactly, but i beleve it's a 10amp fuse on the bottom row somewhere in the middle. if i were you i'd just give them all a once over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amish_assassin88 »</TD></TR><TR><TD CLASS="quote">Ok so I was driving the other day and all of a sudden my gauges stopped working. I have a dx hatch with the cluster with the tachometer installed. My speedo, tach, temp and gas guages dont work. Also my engine lights (CEL, oil, seatbelt, trunk, etc) dont work now either. I also have no turn signals, BUT my hazards still work. I still have lights and highbeams and brakes. Also the high beam indicater light still lights up, while no other light indicaters work....
Therehttps://honda-tech.com/zerothread?id=1966666
Knock yourself out.Should be the one that says instrumentlights and etc.Hope that helps and G/L
hey it ended up being the reverse light fuse!!!!!! I was like wtf? haha. But ya, thanks for the help guys. Appreciate it
akcapr
11
Feb 27, 2011 09:55 PM
blackdx1
Jan 25, 2011 04:47 PM
lluks_844
Jun 1, 2007 05:01 PM
Earthworm Jim
Dec 1, 2005 02:28 PM
