90 ex dome light and center clock( car wont start)
as stated my car wont start and the dome light and center clock wont work. Iwas throwing a code 20 and fixed that but still wont do anything. so as of now no codes.
I have checked rechecked and tripled checked every fuse in the car and in the under hood fuse box
car wants to start the fuel pump and relay arent clicking the first two but the third one gives it power. Ive tried 3 relays already and all did the same thing.so when I crank it it will crank fire and die. it seems as if theres a short somewhere. a couple weeks back I ws trying to put a new bulb in my check engne light spot but I got lazy and just put everything back and when I went to start it a little bit of smoke caem otu from liek the gauge /key area. and I was like wtf. so I just tapped the side of the curved area and it stopped but a da ye later it wouldnt start. Im going to look to see if any wires som how touched and just shorted.think that could be it
yeah more thank likely, have you checked your fuse's in car and under hood one's,
if they are good i would check to see if any of the wires that smoked got fried if they did try to follow them back to see where thy go maybe you burnt out a relay of some sort, and i would take out your cluster to see if you damaged any thing
sckrx
Nov 8, 2006 08:28 AM
BIGBLOCKEK
May 1, 2006 06:02 PM
BOOSTEDgreeneg
Sep 6, 2005 10:06 AM
