I got the car dyno'd today
Old Jan 15, 2008 | 06:31 PM
ludekid4323's Avatar
Default I got the car dyno'd today
edit: bigger pic lol
Because of my cam seal leaking badly and other gaskets leaking oil the tuner fet uncomfortable reving the motor high but I was just wordering if everything looked "ok" to you guys. I dont realy know what I'm looking at
h22a1
Mods:
AEM Cai
AEM Dryflow
Megan Header
2.5 mandrel bent exhaust
Magnaflow muffler
gutted cat
22in resonator
hondata im gasket
Maxbore 64mm tb and im
MSD Wires
Bosch Platinum +4's
UR cam gears, ps and alt pully
removed AC and cruise
Energy suspension motor mount inserts
egr removed
and a bunch of other stuff that prolly dont meen ****
thanks guys
Old Jan 15, 2008 | 06:50 PM
dc2vu's Avatar
Numbers look about right for a mustang dyno. Is that dyno stopping at about 6000?
Old Jan 15, 2008 | 06:52 PM
Default Re: (dc2vu)
yup 5953...plus I dont think he understood that I had an h23 dashboard with an h22. redline with 95 el gauges = lower than 93 vtec dash
Old Jan 15, 2008 | 07:06 PM
dc2vu's Avatar
Well all your mods the numbers look close to right...with similar mods I was estimating 175-180 to the wheels in an EG. It's better that the tuner took precautions not to pull your motor too high knowing theres oil leaking. Rather get off the dyno than blow up a motor.
Odd flat spot at around 4200rpm...I had a similar dip, it's annoying.
Old Jan 15, 2008 | 07:25 PM
mgags7's Avatar
you need to have him rev it another good 1000 rpm if not 1500.
it could use some tuning....
Old Jan 15, 2008 | 07:44 PM
98vtec's Avatar
moderator emeritus
Default Re: (mgags7)
well its not representative of an h22 unless you rev it out. You cut the dyno off at the meat of the engine's power.
and yes, you could use some tuning.
Old Jan 18, 2008 | 12:04 AM
Mpower3's Avatar
Default Re: (98vtec)
tune it ftw
SupraRXZ
Feb 17, 2006 03:02 PM
phryxis
May 25, 2004 07:07 PM
89JDMcrx
Jun 26, 2003 03:11 PM
H23A1LUDE
May 13, 2003 04:06 AM
fe519
Dec 3, 2002 04:36 PM
