3 bolt post mount to a 2 bolt?
Old Jan 15, 2008 | 06:15 PM
rdssk8rcs1's Avatar
Default 3 bolt post mount to a 2 bolt?
How would i go about doing this? Is there a reason i shouldn't do it? The reason why i ask is because i found a good deal on a set of after market mounts that are for a 2 bolt post mount and my 01 ls is a 3 bolt.
thank you in advance
Old Jan 15, 2008 | 06:17 PM
Innes's Avatar
Default Re: 3 bolt post mount to a 2 bolt? (rdssk8rcs1)
just get the 2 bolt driver side portion and install it
shouldn't have any issues at all
Old Jan 15, 2008 | 06:18 PM
rdssk8rcs1's Avatar
Default Re: 3 bolt post mount to a 2 bolt? (Innes)
Where could i get the portion i need? Is it just the bracket piece that i need or there is more to it?
Old Jan 15, 2008 | 06:34 PM
jjspec's Avatar
Local Honda dealer or junkyard should be able to fix you up.
Old Jan 15, 2008 | 06:37 PM
rdssk8rcs1's Avatar
Default Re: 3 bolt post mount to a 2 bolt? (jjspec)
any particular car that came with these that i can look for?
Old Jan 16, 2008 | 10:47 AM
paulzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 &raquo;</TD></TR><TR><TD CLASS="quote">any particular car that came with these that i can look for?</TD></TR></TABLE>
CRV's and 99-00 SI.
Old Jan 17, 2008 | 06:48 AM
rdssk8rcs1's Avatar
Default Re: 3 bolt post mount to a 2 bolt? (paulzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy &raquo;</TD></TR><TR><TD CLASS="quote">
CRV's and 99-00 SI.</TD></TR></TABLE>
And this would bolt up to my ls block and work with innovative 2 bolt post mount motor mounts?
Thanks again for the help
Old Jan 17, 2008 | 07:01 AM
Camp1320motorsports's Avatar
where did you buy the mount kit ?? you should just change it out to a 3 bolt.. if not you can use a JDM b16 or a 99-00 Si driver side post mount... CRV will not work its too tall.!! if you need a 2 bolt post mount i think we got one at the shop...
Old Jan 17, 2008 | 07:02 AM
YZFR6's Avatar
There is a difference between the 99-00 Civic Si timing belt cover mount from the Acura Integra's. The spacing between the two bolts are different. The Acura Integra 94-01 LS/RS is the one your looking for. I'm suprised that you have a 3 post set-up on an LS. Someone must of swapped it out. Any hope this helps.
Old Jan 17, 2008 | 07:09 AM
Default Re: 3 bolt post mount to a 2 bolt? (YZFR6AVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YZFR6AVID &raquo;</TD></TR><TR><TD CLASS="quote">There is a difference between the 99-00 Civic Si timing belt cover mount from the Acura Integra's. The spacing between the two bolts are different. The Acura Integra 94-01 LS/RS is the one your looking for. I'm suprised that you have a 3 post set-up on an LS. Someone must of swapped it out. Any hope this helps. </TD></TR></TABLE>
wait a minute... 94-01 integra all models ls rs gsr type R all came 3 bolt.. i thought you guys were a mount company you should know that.. no LS came 2 bolt 94-01 DC chassis
rdssk8rcs1's Avatar
Default Re: 3 bolt post mount to a 2 bolt? (Camp1320motorsports)
I think mine is a 3 bolt. It has 2 big bolts coming up through the motor mount and it6 appears to be a smaller bolt going down. Is that considered a 3 bolt? And yeah all of this is helping a lot. Thanks
Old Jan 17, 2008 | 07:14 AM
rdssk8rcs1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Camp1320motorsports &raquo;</TD></TR><TR><TD CLASS="quote">where did you buy the mount kit ?? you should just change it out to a 3 bolt.. if not you can use a JDM b16 or a 99-00 Si driver side post mount... CRV will not work its too tall.!! if you need a 2 bolt post mount i think we got one at the shop... </TD></TR></TABLE>
yeah i could definitly use one , if you have the one he is talking about. Is it the civic one or the ls/rs one? Let me know. I would appreciete it a lot
Old Jan 17, 2008 | 08:28 AM
rdssk8rcs1's Avatar
Two bolt of three bolt?
Old Jan 17, 2008 | 08:35 AM
thats 3 bolt
Old Jan 17, 2008 | 08:58 AM
paulzy's Avatar
I've used teh CRV one with a stock civic steel mount with success before. Unless somebody had switched it before hand to a 99-00 Si bracket.
Old Jan 17, 2008 | 04:56 PM
rdssk8rcs1's Avatar
Default Re: (paulzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy &raquo;</TD></TR><TR><TD CLASS="quote">I've used teh CRV one with a stock civic steel mount with success before. Unless somebody had switched it before hand to a 99-00 Si bracket.</TD></TR></TABLE>
What do you mean?
Old Jan 17, 2008 | 05:45 PM
paulzy's Avatar
the 2bolt bracket allows you to use the stock steel mount from teh civic
Old Jan 17, 2008 | 05:58 PM
rdssk8rcs1's Avatar
http://www.innovativemounts.co...19550
So if these are the mounts i buy i can just purchase a 95 civic si 2 bolt post mount?
Old Jan 17, 2008 | 06:03 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (rdssk8rcs1)
Like tony always tells me, Honda put it there for a reason..
Old Jan 17, 2008 | 06:05 PM
rdssk8rcs1's Avatar
Default Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Like tony always tells me, Honda put it there for a reason..</TD></TR></TABLE>
So is that a yes? Haa sorry for being a pain i just want to make sure im purchasing the right thing
Old Jan 17, 2008 | 06:08 PM
paulzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.innovativemounts.co...19550
So if these are the mounts i buy i can just purchase a 95 civic si 2 bolt post mount?</TD></TR></TABLE>
no, the SOHC and DOHC bracket(the piece with the studs and no rubber bushing. Bolts up the the actual engine block) are a different size.
Old Jan 17, 2008 | 06:21 PM
rdssk8rcs1's Avatar
Well i baught the b series one, so would a 92-95 si bracket work?
Old Jan 17, 2008 | 07:10 PM
paulzy's Avatar
yes, the rubber mount from a 92-95 civic will work
Old Jan 17, 2008 | 07:41 PM
rdssk8rcs1's Avatar
yeah thats the part i baught from innovatice. I was asking about the post mount out of a 92-95 si?
Old Jan 18, 2008 | 07:55 AM
paulzy's Avatar
the post mount from a 92-95 Si will not bolt up to a B-series block though.
