Engine making whining noise! need help!!
Old Jan 15, 2008 | 06:07 PM
vi3tromanc3r's Avatar
Default Engine making whining noise! need help!!
My engine is making a whining noise near where all my belts are. its a 95 civic si stock d16z6 motor. and it has 144k miles. I just wanted to make sure if its one of the belt or something else. How do i know which belt is going out if it is the belt or is it best just to change them all.
Old Jan 15, 2008 | 06:11 PM
ek-g6's Avatar
Default Re: Engine making whining noise! need help!! (vi3tromanc3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vi3tromanc3r &raquo;</TD></TR><TR><TD CLASS="quote">My engine is making a whining noise near where all my belts are. its a 95 civic si stock d16z6 motor. and it has 144k miles. I just wanted to make sure if its one of the belt or something else. How do i know which belt is going out if it is the belt or is it best just to change them all. </TD></TR></TABLE>
it probably your alternator belt, but then again could be your power steering, or ac belt. reason its making a whining noise is because its not tighten, or could possibly have some liquid on it.. hope this helps
Old Jan 15, 2008 | 06:12 PM
z6hatchboy's Avatar
Probably would be best and cheap insurance to replace all, but if its while you turn the wheel its power steering, if not that more than likely alternator. Are your lights dimming when it happens?
Old Jan 17, 2008 | 01:52 PM
lights arnt dimming and it happens when im idling. but when i used belt conditioner seem to have went away. will post if it does it again today. thx
Old Jan 17, 2008 | 04:04 PM
joeyd161's Avatar
I also had a whining noise coming from the same location you are talking about. I replaced the Idler pulley and the whining noise was gone, the grease in the pulley dried up.
If you replace the pulley dont get it from Auto Zone cause its plastic. Buy it from Advanced Auto Parts or the stealership because they are metal.
Old Jan 17, 2008 | 04:24 PM
heavyhittersclub's Avatar
Default Re: Engine making whining noise! need help!! (joeyd161)
If you take off the belts off one at a time then run it after to see if the noise is gone, also check all of the pulley first with a stethiscope to see if you can pin point which accesory it is.
If the noise is still there with all the belts off, Check timing belt tension, and all of the puellys.
Old Jan 20, 2008 | 04:36 PM
the noise went away. and now i broke my hood pin for my alarm wen i closed the hood, gayed
GSRpoweredSI
Jun 20, 2007 01:13 PM
Nocturnal
Mar 23, 2006 12:04 PM
90efSI
16
Oct 26, 2005 07:36 PM
stRtypR25
Sep 26, 2002 03:01 PM
jiggajc
Jun 12, 2002 02:55 AM
