Car won't start?Wtf?
Old Jan 15, 2008 | 04:05 PM
apeek's Avatar
Default Car won't start?Wtf?
Some background info. 92 h23
-Somehow blew a headgasket..relaced, put back together started car, timing was just a little off.
-Took off timing belts and all, put them back on,with the timing set perfect(annoying) and today tried to start and it turns over fine but doesnt start!
-I replaced sparkplug wires and ignition to distributor wire, as I couldnt see them sparking in there and now I do with new ones.
-I hear the fuel pump prime the fuel system before I start so I assume I am getting fuel.
I'm pretty clueless here, any thoughts? Thanks!
Old Jan 15, 2008 | 04:24 PM
92nb's Avatar
Default Re: Car won't start?Wtf? (apeek)
There are 3 "general" reasons why a car won't start:
Fuel (pump and filter)
Fire (spark)
Electricity (battery and alternator)
If it turns over (you have electricity coming from the battery to the alternator) and doesn't start, and you're getting a spark, most likely, it's not getting fuel - right?!
Which could mean you're fuel pump isn't working properly and/or your fuel filter needs replacement.
These are just some simple things to go by, and I hope this helps. I think you know the issue here. It sounds like you got it!
Old Jan 15, 2008 | 04:46 PM
JasonST's Avatar
Default Re: Car won't start?Wtf? (92nb)
Sounds like since u've replaced the timing belt the car doesn't start. Which leads me to believe that the timing may be off. U sure u're not off a couple of teeth on the cam gears? Also have u made sure u got ur spark plug firing order correct? And cel's?
Old Jan 15, 2008 | 05:14 PM
apeek's Avatar
Default Re: Car won't start?Wtf? (JasonST)
Yeah that would make sense for the timing to be off, I checked it plenty of times before putting it all back together and checked it again after I tried to start it.
The arrows point up on the cam gears and the lines match up next together as well as the white mark on the flywheel.....
I'll double/triple check spark wires tomorrow as the distributor looks different then the one in the manual i have...*the markings on it look different.
Thanks for the help guys!
baca00ex
Mar 2, 2016 08:04 PM
JDM Freakk
Jun 21, 2011 05:36 PM
Tim2179
Honda Civic (2001 - 2005)
Dec 9, 2010 12:18 PM
dskater4111
18
Aug 5, 2008 10:43 PM
accord-h22
Feb 13, 2007 04:45 PM
