how to remove spray tint from tail lights??!????
Old Jun 30, 2002 | 09:28 PM
sutrusu's Avatar
Default how to remove spray tint from tail lights??!????
im sick of my lights... i want them to look stock. can i just run paint thinner over them? or will i have to sand this **** off??
thanks
eric
Old Jun 30, 2002 | 10:06 PM
JL 74's Avatar
25 Year Member
Default Re: how to remove spray tint from tail lights??!???? (sutrusu)
Try a very fine steel wool. Home depot should have it.
Old Jun 30, 2002 | 10:15 PM
LshatchTurbo's Avatar
New User
Default Re: how to remove spray tint from tail lights??!???? (jl74)
Use rubbing alcohol. If that doesnt work, but it should, goto walmart get a small can of "Aircraft Remover" Rub some on thick towel and whip it offf. I promise u hat will get it off. Be super careful, this **** will take your car paint off as well!
Old Jun 30, 2002 | 10:18 PM
sutrusu's Avatar
Default Re: how to remove spray tint from tail lights??!???? (Zynentech)
lol its called "aircraft remover"?
are you sure its not aircraft paint remover or something like that?
thanks!
Old Jun 30, 2002 | 10:25 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
you guys are taking it too far.
just go to a grocery store, pick up a bottle of simple green for $8, and use it (full strength). if that doesn't work, use tar/bug remover.
both worked fine for me.
Old Jun 30, 2002 | 10:29 PM
sutrusu's Avatar
rubbing alcohol didnt do ****. are you sure steel wool will be ok? i dont want to REALLY **** these up.... what about sand paper? what grit sandpaper should i use? wet?
thjanks for hte suggestions...
Old Jun 30, 2002 | 10:30 PM
sutrusu's Avatar
Default Re: how to remove spray tint from tail lights??!???? (dLo GSR)
simple green?
the tail lights have the tint spray and a rustoleum clearcoat on them.
New User
that what i meant aircraft paint remover.
Old Jun 30, 2002 | 10:39 PM
sutrusu's Avatar
okay... i will try the aircraft paint remover tomorrow...
thanks for the suggestion.. any last words?
Old Jul 1, 2002 | 01:31 AM
RoaringTurtle's Avatar
New User
i wouldnt use that aircraft paint remover on plastic
yes it will take the tint off
but i bet it will melt the plastic along with it
acetone is used to remove paint as well
but use it on certain plastics and the plastic will start to melt and deform
Old Jul 1, 2002 | 04:49 AM
IC x Prince's Avatar
New User
Default Re: how to remove spray tint from tail lights??!???? (RoaringTurtle)
No you were right the first time...it's aircraft remover...but it will melt your taillights...try some nail polish remover from sally's the industrial kind. It will leave your tail lights hazey, just wet sand them and re clear coat.
Old Jul 1, 2002 | 08:51 AM
sutrusu's Avatar
Default Re: how to remove spray tint from tail lights??!???? (UltraGSR)
aah too much work. i'll just buy some used ones.
Old Apr 23, 2003 | 06:19 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
back from the dead.
anyone else have ideas on how to remove this?
Old May 14, 2003 | 02:45 AM
uNF$@#!'s Avatar
Default Re: how to remove spray tint from tail lights??!???? (fnananon)
acetone. (your nail polish remover)
take a large pan, and dip the portion of the light in....keep checking...when the film begins to desolve, remove and wipe clean.
Old May 15, 2003 | 09:24 AM
B_CRUZ!'s Avatar
lacquer thinner will work. I have done it before. Use a towel and do it in a well ventilated place. wax it when you are done.
Old May 15, 2003 | 09:42 AM
ebelp's Avatar
Default Re: how to remove spray tint from tail lights??!???? (BCRUZ)
I think no matter which route you go, your taillights aren't going to look normal after you strip off the tine spray. If you sand them, they'll turn cloudy and dull. If you use the aircraft stripper, you run the risk of deforming the plastic. Too risky if you ask me.
Old May 15, 2003 | 10:51 AM
Kryptonite's Avatar
Default Re: how to remove spray tint from tail lights??!???? (ebelp)
aircraft remover does the trick you can get it from pepboys, auto zone etc....
all you gotta do is spray & wipe with a plastic (the kind you use to kneed dough with).then wash off with water......its that simple!!
Old May 15, 2003 | 10:55 AM
B_CRUZ!'s Avatar
aircraft paint remover will eat through some of the plastic. I have been using this stuff for years.
Lacquer thinner won't. Done this many of times for my friends who painted theirs back in 97.
Old May 15, 2003 | 02:10 PM
simplegreenmachine's Avatar
GOOF OFF....2.49 a little bottle and it will work
Old May 15, 2003 | 02:13 PM
iam7head's Avatar
Default Re: how to remove spray tint from tail lights??!???? (MonKey Magic)
i dont recommed using the paint stripper..i will eat your plastic layer away.
goof off, nail polish remover prolly wont do sh_t.
lol do it the redneck way, spray alot of paint over the lens, let the paint soak for a min or so and then rub it off with thinner
Old May 16, 2003 | 11:35 AM
bert039's Avatar
Default Re: how to remove spray tint from tail lights??!???? (iam7head)
if you have that store 'TAP Plastics' in your area, go there and ask for this chemical that removes graffiti and spray paint off of any glass or plastic material, the guy at the store told me that people use it to remove graffiti from vending machine windows. i used this on my friend's tail lights and it worked great. it completely removed the black tint from his tail lights and didn't hurt the plastic at all. i don't remember the name of the chemical (it's been like 5 years) sorry.
Old May 16, 2003 | 11:42 AM
gsrstyle's Avatar
used this stuff called "SEM SOLVE" to take the paint off my corner lights. They're as good as stock now.
I bought the stuff at some car paint store.
Old May 19, 2003 | 08:21 PM
KOALA YUMMIES's Avatar
Default Re: how to remove spray tint from tail lights??!???? (gsrstyle)
Aircraft Remover will destroy your tailights. Tried it on OEM turnsignals, it will eat the plastic. Use "Goof Off" the aerosol kind, its paint thinnner in a can.
Old May 19, 2003 | 08:42 PM
milo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BCRUZ &raquo;</TD></TR><TR><TD CLASS="quote">lacquer thinner will work. I have done it before. Use a towel and do it in a well ventilated place. wax it when you are done.</TD></TR></TABLE>
there's your answer
Old Jun 18, 2004 | 10:32 PM
Calsonic's Avatar
Default Re: how to remove spray tint from tail lights??!???? (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">Aircraft Remover will destroy your tailights. Tried it on OEM turnsignals, it will eat the plastic. Use "Goof Off" the aerosol kind, its paint thinnner in a can.</TD></TR></TABLE>
Back again from the dead. Where can I buy "Goof Off"?
