Alarm malfunction
I dont have my keyless entry anymore, I lost it
So my alarm system doesn't arm at all
However, the other day when i unlocked my car with my key, the alarm went off, nothing i could do would turn it off except for disconnecting the wire from the horn. The red alarm light inside the car blinks constantly now even when the car is on or off. Also it makes a ticking sound for a few seconds and the side markers outside blinks for about 10 seconds when i turn off the car.
However it only happens sometimes randomly, its extremely annoying, I already disconnected the battery and reconnected it.
Any suggestions?
Any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macdriver »</TD></TR><TR><TD CLASS="quote">Have you considered a licensed mechanic?</TD></TR></TABLE>
Wtf do you need a mechanic for about keyless entry?
I see you just posted in the camber thread also saying "Have you considered a licensed camber dude"? Just stop posting...
On a factory keyless entry you should be able to just turn the key in the door and shut off the alarm but if that doesn't work try the trunk. Unhooking the battery shouldn't disable the alarm. Other than that you might have an aftermarket alarm. Keylessride sells remotes to those also. I buy a ton of remotes from them.
jamzm101
Jul 19, 2007 04:33 PM
