need halp with injectors on h22 swap
Old Jan 15, 2008 | 07:55 AM
boosted92hatch's Avatar
Default need halp with injectors on h22 swap
hey whats up, i would like 2 know if anyone has information on rather or not i need to wire in a resistor box on 97 h22a4 engine for my civic. or are these injectors the same as the obd2a injectors that came in the car wich i believe are saturated. any help is greatly appreciated. thank you in advance
Old Jan 15, 2008 | 07:58 AM
Default Re: need halp with injectors on h22 swap (boosted92hatch)
also if anyone can tell me what lower radiator hose to use, some say stock prelude and others say del sol vtec lower hose but is it the z6 or the b16 hose the car is a 96 civic. again thanks for the help
Old Jan 15, 2008 | 10:51 AM
ESP.net's Avatar
ob2a saturated
H22a4 saturated
Saturated= no need for resistor box that is a peak and hold thing...
Lower radiator hose:
Use a piece of pipe that will fit in between the 2 hoses use 2 screw clamps
Prelude hose to engine and civic on the other end put the pipe right where the contour goes down over the transmission to the radiator... obviously an area with no curve or bend in and is straight...
Just make sure to measure twice on the contour you want to cut for the hose before you do it
IAluder95
Jul 31, 2007 08:36 PM
shooitzlinh
May 27, 2005 11:37 AM
DropSquadCivic
Aug 14, 2003 07:16 AM
