thermostat Question "please help"
Roaming Idle problem roams up and down once it has warmed up.
Replaced IACV.
Flushed coolent system and purged bleeder valve started car let run for 10 min. fan came on twice then refilled and topped off level. Still same problem.
93 honda civic si stock 242,000 miles. Could a bad thermostat cause a roaming idle. And body have any clue what I could check next.
Thank you for your help!!!!
Phil
Replaced IACV.
Phil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! »</TD></TR><TR><TD CLASS="quote">isnt there a thread with the roaming idle fix procedure? search son
x 1000
did you check for vacuum leaks?
</TD></TR></TABLE>x 1000
