Clunking sound when I turn my wheel.
Old Jan 15, 2008 | 03:48 AM
Charismatica's Avatar
Default Clunking sound when I turn my wheel.
I got TEIN basics on my 02 RSX S about 3k ago. Theres a clunk sound whenever i turn my wheel. My coworker said it might be because the strut mounts that are on there right now are stock ones. Where can I find aftermarket strut mounts. Should they have come with the coilovers? Any other idea what is cause the clunkin noise?
Thanks
Old Jan 15, 2008 | 05:30 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Clunking sound when I turn my wheel. (Charismatica)
Obviously something is loose/not on correctly.
Have someone turn the wheel and listen to where the noise is coming from.
Your co-worker doesn't know what they are talking about as those coilovers are designed to work with the OEM parts.
Old Jan 15, 2008 | 05:49 AM
Rkrd25's Avatar
Default Re: Clunking sound when I turn my wheel. (Todd00)
i have the same problem, just had mine installed, same tein and its only in the right front wheel, it seems like nothing is loose, but cant put my finger on it
Old Jan 15, 2008 | 07:35 AM
NTCustoms's Avatar
the clunking noise is probably the spring not seated right on the perch. as todd said have someone turn the wheel while you listen to it
Old Jan 15, 2008 | 05:43 PM
macdriver's Avatar
I suggest bringing your vehicle to a licensed mechanic.
Old Jan 15, 2008 | 11:15 PM
NTCustoms's Avatar
i sense a troll...
Old Jan 16, 2008 | 02:06 AM
Default Re: (NTCustoms)
coming from the springs... hmmm the sound stops for a while whenever i adjust my height.
Old Jan 16, 2008 | 06:03 AM
Todd00's Avatar
Default Re: (Charismatica)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charismatica &raquo;</TD></TR><TR><TD CLASS="quote">coming from the springs... hmmm the sound stops for a while whenever i adjust my height.</TD></TR></TABLE>
You realize that everytime you adjust your height, you throw your alignment off.
Who did the install? Take it back to them. There is one of many things that could be causing the sound and we can't keep randomly guessing at what it is.
Old Jan 17, 2008 | 10:09 AM
Zero Signal's Avatar
check the top nuts on the struts
Old Jan 17, 2008 | 03:25 PM
albertleee's Avatar
Default Re: (Zero Signal)
go over a speed bump at like 50 mph and your problem will be fixed
Old Jan 18, 2008 | 07:55 PM
vhugoyz's Avatar
SELL YOUR CAR
Old Jan 18, 2008 | 10:07 PM
boynblue's Avatar
http://www.pdm-racing.com/products/suspension.html
Go to this website an scroll down to part Suspension Techniques Coils Silencer. The stock coils come with these on as well but its black and not seperated. I am going to buy them for my car soon cuz I got sound after installing my hotchkis springs. Good Luck. Get back if you try this an it works.
Old Jan 20, 2008 | 02:25 AM
FFerio's Avatar
Default Re: Clunking sound when I turn my wheel. (boynblue)
thankx everyone i will keep u updated
Old Jan 20, 2008 | 01:09 PM
rac3rsx's Avatar
check your tie rod end joints, they might either be worn or leaking which can make a clunk sound when youre turning your wheel/
Old Jan 22, 2008 | 07:04 AM
jsantosDC5's Avatar
had that problem with my flex's... it was bcz the spring was not propoerly tightened all the way... make sure that the spring is sitting correctly(like twist it around) and make sure everything is tight from the strut mount to the plates that adjusts the height
Old Jan 22, 2008 | 12:00 PM
dc5Aspec'd's Avatar
I had that sound after I ran over a tracker trailer tire on the highway. In my instance it was a bent strut causing the sound. The strut would put stress on the spring when you would turn the wheel and once it was fully stressed it would pop and reposition its self.
Old Jan 31, 2008 | 12:20 PM
.:Swig:.'s Avatar
Default Re: Clunking sound when I turn my wheel. (dc5Aspec'd)
if needed i have some spoon strut mounts for an rsx(brand new still in spoon packaging), shoot me a pm if interested
Old Jan 31, 2008 | 04:08 PM
dc_love's Avatar
i had this same probem exactly as you described....i installed skunk2 coilover sleeves. and the clunking was happening whenever i turned the wheel.
for me, it was a case of bad design on skunk2's part. sitting on top of the spring is an aluminum cap that doesn't turn with the spring. when you have your car lowered a lot, there is more compression and then when you turn the wheel, the clunking sound is the result of your steel springs rubbing up against the aluminum cap. the sound stopped when i raised the car about an inch.
but its probably something similar to this above ^
Old Feb 5, 2008 | 06:37 AM
ShAii's Avatar
Default Re: Clunking sound when I turn my wheel. (dc_love)
does it do the noise when you turn the wheel while the car is moving? or when the car is at a stop?
Old Feb 7, 2008 | 12:26 PM
Default Re: Clunking sound when I turn my wheel. (ShAii)
thankx you everyone
butterblum
Honda CR-V & Element
Sep 23, 2017 06:32 AM
anello16
Jul 14, 2009 09:56 AM
1_slow_crx
Sep 1, 2006 09:46 AM
Sephro
Oct 11, 2002 10:34 AM
