H22 head to F22B1 BLOCK
Old Jan 14, 2008 | 09:44 PM
Socalf22's Avatar
Default H22 head to F22B1 BLOCK
So I've wanted to switch the head from an H22 or possibly h23 to my F22b1 Its cheaper (or should i just buy a complete swap to avoid problems) .....I know im going to have to buy the ECU and Harness Etc... anyway anyone know if i would have to plug or make any extra hole's you know for like the oil and what not? and I done some research and Ive read some threads where people said the pistons would also have to be changed and others say the stock one's on the f22b1 would work fine ? so to change or not to change is the question......
Old Jan 14, 2008 | 11:48 PM
YeuEmMaiMai's Avatar
Default Re: H22 head to F22B1 BLOCK (Socalf22)
you can do it and it will give some good results pretty much plug and play
Old Jan 15, 2008 | 02:43 PM
Andryzzle's Avatar
Default Re: H22 head to F22B1 BLOCK (YeuEmMaiMai)
there are a few walkthroughs but i dont think any apply specifically to the f22b1
Old Jan 15, 2008 | 07:49 PM
sony224422's Avatar
its the same block as the f22b2.
also, the h22 is not a direct swap, the h23 head is the same as the f22 dohc from japan.
and 3rd look in the faq there is a 120+ page write up.
Old Mar 4, 2008 | 07:39 PM
Socalf22's Avatar
Default Re: H22 head to F22B1 BLOCK (sony224422)
You got me a little lost... So could I use an H23 head on an f22b1 as well? btw
Would i be able to use the compu form my f22 or would i have to get the h22 one.?
Old Mar 5, 2008 | 04:03 AM
TouringAccord's Avatar
H-T Order of Merit
try doing some searching and also look through the swap links in the FAQ. That should help answer most of your questions.
Like Andryzzle stated, none of the write-ups deal specifically with the F22B1 but they do deal with the F22B2 block and F23A1 block which are both going to be very similar.
Kwalsh24
Mar 20, 2006 09:22 PM
allmotorcrx1987
Dec 26, 2005 12:24 AM
boostin1cam
Nov 15, 2005 08:09 PM
H23LUDE92
Jul 14, 2004 08:19 PM
armharm
Oct 4, 2002 06:58 AM
