EJ8 help!
Old Jan 14, 2008 | 11:23 AM
mortificationrock's Avatar
Default EJ8 help!
Ok i just puchased this car and im trying to figure some things out.First i have the OEM remote (alarm) my car unlocks and locks but i have no sort of siren i guess?Or do I? where or what should i look for.Also does anyone know if the remote or the car comes with a feature to open trunk with oem remote?
Old Jan 14, 2008 | 11:55 AM
MilanoCivic97's Avatar
Default Re: EJ8 help! (mortificationrock)
no siren. no trunk opening feature.
Old Jan 14, 2008 | 12:01 PM
B18CivicEJ8's Avatar
Most likely, the stock remote you have is for keyless entry. There was an alarm option from the factory, but most people didn't get it because it's cheaper to get an aftermarket alarm. As far as opening the trunk remotely, you'd probably need to get an aftermarket alarm and have an actuator installed to do so. I'm not sure how to do it myself, but nowadays anything is possible.
Old Jan 14, 2008 | 12:02 PM
Default Re: EJ8 help! (MilanoCivic97)
Well that sucks ***!Damm what kind of keyless function is this?Anyways thanx I was just curious !
Old Jan 14, 2008 | 02:26 PM
NOFX's Avatar
H-T White Ops
If you have the alarm it should be under the seat IIRC. The factory keyless just unlocks and locks the doors (and you can press and hold the option button to make it beep when you lock and unlock it).
For the '96-'98 models, the keyless is on the stock headunit. So if you remove it, it will no longer work.
There's nothing connected to the trunk and no actuator back there, so no, the keyless entry won't open it.
DCFIVER
Acura TL, RL & ZDX
Mar 28, 2011 06:07 AM
HRPfg2
Honda Civic (2006 - 2015)
Jul 5, 2006 09:23 PM
GoLowDrew
Audio / Security / Video
May 30, 2006 03:37 PM
Spoogen_1
11
Apr 22, 2005 04:07 AM
toohott4handlin
Apr 10, 2005 10:24 PM
