CRX SiR b16a oil leak
Hey guys, i have an oil leak pictured below, around the vtec solenoid.
http://67.55.76.55/crx/leak_3.jpg
It looks like i need to change upper gasket, and/or head to solenoid gasket?
On my CRX, the B16A comes with Y-1 and LSD, which means it came from 90-91 CRX SiR, therefore it's a OBD-0. At first I need the part# from 94 Del Sol Vtec or 99 Civic Si, but then i found this post (exactly my issue)
https://honda-tech.com/zerothread/2173498
This post talks about the part from 90-91 Acura NSX
Which dealer and part # do i need, from which model?
I appreciate your help!
Ok, after a bit of digging online it appears that the answer for
JDM CRX SiR B16A/OBD-0 Vtec solenoid gasket is:
1991 NSX part # 15825-PR3-005
Source:
https://honda-tech.com/zerothread?id=996694
WHAT else that leak may be? Can it be cam seal or head gasket in addition?
Source:
Hey Guys, thanks for your help. I replaced 2 vtec solenoid seals, 2 cam seals on the driver side and a cam plug seal on the passenger side. Changed the valve cover seal as well. Looking good now.
Thanks for all your help!
Yobee
Dec 9, 2012 08:16 AM
coot_er
Aug 15, 2005 12:36 AM
madman13lm
Feb 21, 2003 06:13 AM
