h22a alternator belt
Old Jan 14, 2008 | 10:25 AM
Infinity_Racer's Avatar
Default h22a alternator belt
I was just curious, for the people that have done an h22a swap on their 4th gen and kept their h23 alternator/ac, you use the h23 belt because it only has 5 ribs right? Or did you just change out the pulley altogether and put the h23 pulley on the h22a? Currently, im running the h22a pulley with the 5rib h23 belt.
Old Jan 14, 2008 | 10:40 AM
Hawkze_2.3's Avatar
Default Re: h22a alternator belt (Infinity_Racer)
I use a D-series alt with only a 3-rib belt so if you just have 5 instead of 6 it should be fine.
Old Jan 14, 2008 | 10:58 AM
Default Re: h22a alternator belt (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">I use a D-series alt with only a 3-rib belt so if you just have 5 instead of 6 it should be fine.</TD></TR></TABLE>
sounds good to me...i was just making sure
any reason why you're using a d series? no a/c?
Old Jan 14, 2008 | 08:02 PM
sean1121's Avatar
I'm running all H23 pulleys/belts on my H22.
Old Jan 14, 2008 | 09:02 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infinity_Racer &raquo;</TD></TR><TR><TD CLASS="quote">
any reason why you're using a d series? no a/c?</TD></TR></TABLE>
No AC, no PS and the D-alt and Explicitspeed bracket are smaller and lighter than stock.
bb4socal
Aug 11, 2008 06:57 PM
Prudz_lude
Oct 12, 2006 04:02 PM
95PreludeSi
Dec 8, 2004 04:38 PM
Sick'Lude
Dec 7, 2004 10:41 AM
GOTNOS
Sep 26, 2004 02:21 PM
