Suspension & Brakes Theory, alignment, spring rates....
Lowering Springs HELP..ASAP
Old Jan 14, 2008 | 10:04 AM
jdelima87's Avatar
Default Lowering Springs HELP..ASAP
I Just Installed Sum Skunk 2 Lowering Springs On My 05 Civic...and For Some Reason Wen I Turn The Wheel It Makes Like A popping Sound....i Told Sum One To Help Me Out..and As They Turned The Wheel My Spring Is Moving Inside The Strut...i Think I Did Everything Right And I Dont Kno Wats Wrong...can Sumbody Tell Me Wats Goin On?......thnx Alot...appreciate The Help...
Old Jan 14, 2008 | 05:35 PM
jdelima87's Avatar
Default Re: Lowering Springs HELP..ASAP (jdelima87)
no help???
Old Jan 14, 2008 | 06:26 PM
little dx that could's Avatar
did you lock them in. just did that on my 94 civic. noticed lock in to the struts. they sit in a groove. luckily i noticed before we got done and fixed it. check to see if there sitting in the groove. you might have to pull it apart agian. hope this helps
Old Jan 14, 2008 | 08:18 PM
Untamed_Hatred's Avatar
is it a coilover set or just springs. if its a coilover set there should be gaskets that go on the strut and hold the adjustment pice in place. the spring then sits in a groove like the person said before me. if its a spring make sure the spring is set correctly on the base support for the spring on the strut and the groove at the top. if that doesnt work try turning the spring so that the end of it is not facing out
Old Jan 15, 2008 | 05:37 AM
jdelima87's Avatar
Got it...thnx...appreciate it...both u guys...
Kaligrown
Suspension & Brakes
Jul 14, 2014 09:47 AM
i-VTEC_do_you
Suspension & Brakes
Mar 13, 2011 05:31 AM
Justin Jones
Oct 17, 2004 07:44 PM
Naturally Aspirated
Sep 21, 2004 06:23 PM
