Using 97auto engine harness on manual transmission?
I have looked up the part numbers and they are different, however, i would like to know if it is possible to use this harness without any problems? I dont mind rewiring minor things. Is the TCM harness separate to that of the engine harness?
reason i ask is because i need to see if the wiring that i did on my build is the issue of not getting spark and there is a uncut auto harness on ebay right now for very cheap.
any help to getting my project finished is great appreciated.
If it's cheap buy it so you can check it out, and then if you don't need it sell it again.
But to answer your question no, I don't know if it will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq »</TD></TR><TR><TD CLASS="quote">No problem- you'll get some AT plugs left hanging and you'll have to make a new connection for the back-up light.</TD></TR></TABLE>
i was actually hoping you would be the one to post
thanks alot!
thanks alot!
Hittnthebz
Dec 20, 2007 06:13 PM
Pandahatch
Welding / Fabrication
Dec 27, 2006 08:08 PM
