Does zc Head Bolt up To d16a6 block?
Old Jan 14, 2008 | 09:46 AM
91EF9lover's Avatar
Default Does zc Head Bolt up To d16a6 block?
Well i tried searching but i can search "zc" because its a 2 letter word and its unable to so im asking here i have heard that a zc dohc head can bolt right up to the a6 block if so im gonna do it to add to my already turbo'd built a6 with 8.9:1 CP Ration and Eagle rods but will this head raise compression at all and can i reuse my skunk 2 intake manifold and distributor and wiring harness?
Old Jan 14, 2008 | 10:18 AM
twiztid17thninja's Avatar
Default Re: Does zc Head Bolt up To d16a6 block? (91EF9lover)
i am pretty sure that you can't use the dohc zc head on on an a6 or an sohc zc for that matter you could use a y8 vtec head for about the same hp gain and a little more torque or the zc sohc vtec head.
Old Jan 14, 2008 | 10:30 AM
CRX Toad's Avatar
No it will not bolt on in the sense of a bolt on intake.
Old Jan 15, 2008 | 11:51 AM
hondasaurusrex's Avatar
Default Re: Does zc Head Bolt up To d16a6 block? (CRX Toad)
no...a dohc zc head on an A6 block wont work...its been done, but fails horribly every time...why dont you just get a z6 head and go vtec??
chris riz
12
Sep 22, 2011 12:34 PM
92hatchboi
Sep 28, 2007 08:23 AM
Tyounin608
Dec 21, 2006 08:37 AM
jdm_eqsi
Sep 30, 2005 11:00 PM
the jdmchop
Feb 3, 2004 10:12 AM
