how do I know my 96 honda accord tranny is slipping?
Old Jan 14, 2008 | 09:46 AM
nickoz's Avatar
Default how do I know my 96 honda accord tranny is slipping?
Well my car has been acting up. its a 1996 honda accord ex vtec. (AUTO)
when i put it in drive, it feels like its n between a gear.. and its not shifting. i have to hit the gas alittle more for it to change gears. would this mean the tranny is slipping? i know my car has check engine light on. i read the code and its saying its mifireing 3rd cylinder... would this cause the problem? mab a sensor?
p.s... i havent changed the tranny oil since i got car. i only put 15,000 on it.. but not sure when it has been flushed. motor oil changed every 4000-5000.
any help would be great!!
thanks n advance.
Modified by nickoz at 11:11 AM 1/14/2008
Old Jan 14, 2008 | 11:05 AM
awdgsx96's Avatar
Default Re: how do I know my 96 honda accord tranny is slipping? (nickoz)
Do you mean from the neutral to D4 switch, it doesn't move until you push the throttle?
You say you put 15k on it, how many original miles are on the car? Do you have a service record of when the tranny fluid was done if at all?
Old Jan 14, 2008 | 06:08 PM
nickoz's Avatar
well not sure on records... and there is 236,000 on it. when i bought it , emmisions n alll were GREAT! passed all no problems. now... im afraid.
n yah.. when i put it on D4 it moves... but it shakes the car when im driving.. like its not shifting. kinda like a jerkage till i press gas little more.
i checked tranny oil n all... all is good.. tranny fluid nice n red... Full too.. so im not to sure.
would misfire cause jerkage n all.. says misfiring 3rd cylinder.
Old Jan 14, 2008 | 06:43 PM
YeuEmMaiMai's Avatar
change the trans fluid. as the fluid gets older it gets thicker and will cause delay in gear engagement especially in cooler weather.
put some new plugs wire and cap on to fix the misfire
Old Jan 14, 2008 | 06:56 PM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickoz &raquo;</TD></TR><TR><TD CLASS="quote">well not sure on records... and there is 236,000 on it. when i bought it , emmisions n alll were GREAT! passed all no problems. now... im afraid.
would misfire cause jerkage n all.. says misfiring 3rd cylinder.</TD></TR></TABLE>
A misfire would definetely cause the car to jerk and hesitate. Do as YeuEmMaiMai says and see if that clears the misfire problem
Old Jan 14, 2008 | 08:44 PM
nickoz's Avatar
Default Re: how do I know my 96 honda accord tranny is slipping? (awdgsx96)
i changed the wires not to long ago cuz this misfire... didnt change the distrubutor cap.. didnt have no more money, but i cleaned it out.. still happening... mabe it needs to be replaced? if i replace the fluid n cap... do i have to change plugs since i just changed them like month ago cuz misfire... one plug was all coroded...
Old Jan 14, 2008 | 09:01 PM
SkimN's Avatar
when you do change the cap I recommend changing the rotor inside also
Old Jan 14, 2008 | 09:21 PM
Default Re: how do I know my 96 honda accord tranny is slipping? (SkimN)
yah new rotor as well I always replaced them as a set that's why i didn't mention it
a fouled or damaged plug can cause a misfire and so can oil in the tube
you will need to pull and inspect each plug
Old Jan 15, 2008 | 06:12 AM
poland accord's Avatar
dude just change your trans fuild mine does the same at now 120,000 i mean that still really good for auto trans to last , but also it also depends if you've ever changed your trans too. anything over 140,000 on trans you should replace depending on how late the shifts are.
Old Jan 15, 2008 | 06:14 AM
when i mean replace i mean the whole trans it will cost an average for good one with low mileage like 800bucks
Old Jan 15, 2008 | 11:24 AM
nickoz's Avatar
Default Re: (poland accord)
yahhh ill have to go through n insect all. how much rotor n cap cost approx?
yahhh im kinda thinkin new tranny mabe... but i going to check fluid n cap n all first. then if not, ill bring it to somewhere n test the tranny out .. or something, since i have no clue on what to do. or tools.. etc.
Old Jan 16, 2008 | 06:33 AM
well have someone check but most any honda transmission over 140,000 miles is an instant just replace. even if you floor it quite few times
Old Jan 16, 2008 | 09:10 AM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickoz &raquo;</TD></TR><TR><TD CLASS="quote">i changed the wires not to long ago cuz this misfire... didnt change the distrubutor cap.. didnt have no more money, but i cleaned it out.. still happening... mabe it needs to be replaced? if i replace the fluid n cap... do i have to change plugs since i just changed them like month ago cuz misfire... one plug was all coroded... </TD></TR></TABLE>
Do you remember which cylinder it was? And what plugs are you going with? If you mentioned it being fouled, was it with oil or fuel? The plug o-rings may need to be changed, it's like $20 from Advance or whatever and replaces the VC gasket and spark plug gaskets
Old Jan 16, 2008 | 05:52 PM
nickoz's Avatar
stock bosh plugs i put in...was broke at the time. and its misfiring cylinder 3. i didnt read it. and when i asked machanic.. he says its misfiring.. he said problem cud be wires n all... so i replaced all except dis cap.
Old Jan 16, 2008 | 08:53 PM
pos_cd5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickoz &raquo;</TD></TR><TR><TD CLASS="quote">stock bosh plugs i put in...was broke at the time. and its misfiring cylinder 3. i didnt read it. and when i asked machanic.. he says its misfiring.. he said problem cud be wires n all... so i replaced all except dis cap.</TD></TR></TABLE>
BOSCH?! you bastard. NGK or nothing fooooo! copper bosch plugs at my work (autozone) are $1.89, for 20 cents more you could've got OEM NGKs @ $2.09. and at other auto places, NGKs can be had for under $2.
DamTru
Jul 14, 2011 06:31 PM
98bucket
Sep 7, 2010 04:18 AM
plumers
Apr 30, 2005 05:42 PM
DaChoZn1
Apr 10, 2004 06:29 PM
